Step Deck Vs O-Rings
Old Nov 15, 2011 | 11:43 PM
Lyle_57IAL's Avatar
Default Step Deck Vs O-Rings
Hey guys,
Running a D16z6 block with a D16y8 head. Currently had a few head gasket issues and looking to both re-engineer my setup a little stronger and also go for a more conservative timing values with my tune.
I am wanting to achieve a better headgasket seal.
Currently have Dart Sleeves, Cometic 1.3mm MLS head gasket, 76mm Bore.
Wanted to know the Pro's & Con's of O-rings Vs a step deck and what would be the better path to go down etc or possibly both?
Thanks in advance !
Old Nov 16, 2011 | 03:16 AM
MR.johnson's Avatar
Default Re: Step Deck Vs O-Rings
im going 100% flat this year. had issues with my step
Old Nov 16, 2011 | 06:09 AM
methodz55's Avatar
Ivee done step deck worked great I flat my block stepped it .030 the same as my hg with arps never had a problem with gasket never did o ring I heard if not done right could cause sealing issues
Old Nov 16, 2011 | 06:32 AM
kbouchard1092's Avatar
i think you might be mistaken...step decks are usually .003" if youre sleeved stuck out that high it would never seal. That doesnt make much sense.
Step decks are becoming less poplular. O-ringing is most definatly a better method. Alot of people with Hondas do the copper o-rings (which is what i have) Although some people do use stainless wire with a reciever groove in the head. Ive also heard that some dont use the reciever groove with MLS gasket. I think copper wire is defintaly most common within the honda community tho
Old Nov 16, 2011 | 06:44 AM
Muckman's Avatar
Moderator in Chief
What kind of head gasket is used when a receiver ring is used in the head?
Old Nov 16, 2011 | 07:00 AM
i would say with a stainless wire and reciever groove in head then a copper headgasket would be used....I have heard of people using stainless without a reciever groove with a MLS gasket.
But without a doubt i would say 95% of honda builders out there go Sleeve of thier choice with Copper O-rings
.adam.
Jul 18, 2014 09:32 PM
SIReg9
Aug 10, 2012 12:57 AM
2lude4u
Jan 31, 2006 06:16 PM
92HB_HB
Sep 12, 2005 09:28 PM
civiceg500
15
Feb 6, 2005 06:06 AM
