GSR IN EG HELP!!!
I JUST BOUGHT A JDM GSR OFF MY BOY, HE HAD IT IN AN 00 SI COUPE IM GONNA PUT IT IN MY 95 EG/EX, I JUST WANNA KNOW WHAT I NEED TO MAKE THIS WORK.
I.E WHAT HARNESS? WHAT DIZZY DO I USE? ETC AN AND ALL HELP WOULD BE APPRECIATED
Here's a link since the search isn't working for you.
https://honda-tech.com/forums/hybrid-engine-swaps-18/definitive-guide-gsr-eg-swap-2976738/
From: Pensacola, FL and every Court House in Louisiana
Get a obd2 wiring harness and don't mess with your injectors, alt, or dizzy. Get obd1 ecu. You will have to wire vtec and knock sensor from the shock tower to the ecu. Then DRIVE.
I am restoring a 94 and swapped a 99 gsr into it over the weekend. It is not worth buying obd1 injectors, alt, dizzy when you already have it. Buy a obd2 ls harness for $40 and wire in the needed wires or buy a gsr harness for twice as much.
zamboolicious
Feb 6, 2008 05:44 PM
