y7/z6 mini me jumping timing
Old Nov 14, 2011 | 08:51 PM
CivicxTree754's Avatar
Photogenic
Loved
Default y7/z6 mini me jumping timing
Everytime I rotate the belt after setting the timing the belt slips and moves the timing off a tooth at a time. Any help? Im also using the z6 cam gear, z6 belt and z6 water pump. Belt is extra tight.
Old Nov 14, 2011 | 08:59 PM
FOGO_EK9's Avatar
Default Re: y7/z6 mini me jumping timing
What block are you using? y7 or z6?
If you are using the y7 block, use a y7 water pump and z6 T-belt. This is how I have my setup.
Old Nov 14, 2011 | 09:02 PM
Photogenic
Loved
Yes im using a y7 block. Taking the water pump off now. Thanks. Will update if problem is solved.
Old Nov 15, 2011 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
Yeah what water pump were you using?
From another thread:
Z1/Z6 water pump is 19 teeth approx 55mm OD
B2/A6 water pump is 19 teeth approx 54mm OD
Y7/Y8 water pump is 19 teeth approx 56mm OD
crxsi1
12
Aug 1, 2013 12:32 PM
Ser1N
Jun 14, 2012 05:15 AM
kracer
Jan 28, 2007 12:18 AM
joboost13
Feb 10, 2005 12:09 PM
YumVTEC
Sep 27, 2004 11:54 AM
