Code 7...already checked voltages
Old Nov 13, 2011 | 09:05 AM
97CWITR's Avatar
Default Code 7...already checked voltages
Car has been hesitating for a couple days on the hwy, and then got a lot worse today. Threw a code 7 for TPS sensor finally...
Back pinned the tps sensor and got .5V at closed, and 4.5V at wot, and rises steadily from closed to open with no dead spots.
So what is my next step? Replace the whole sensor?
Old Nov 13, 2011 | 09:48 AM
hybridmiklo's Avatar
Default Re: Code 7...already checked voltages
Its super super hard to see a deadspot if you are using a voltmeter. Shake the wiring while you check the voltages to make sure there isn't a short within the harness. If all good, replace the sensor.
Old Nov 13, 2011 | 11:24 AM
NOFX's Avatar
H-T White Ops
Good luck. I've got the same code in my '88 CRX and I'm having a hell of a time. Two TPSes, TPS checks out, wiring checks out, two ECUs, swapped the O2 sensor (that got rid of the CEL, which was CEL 7/TPS), but the car still has the bucking. My CEL only would come on when the car would run perfectly btw. If the CEL was off the car ran poorly.
It started out as slight hesitation but has gotten far more violent as time passes. It's so bad that to get the car home last night I had to unplug the TPS and drive home like that (but it causes the car to go from 43mpg to 28mpg).
Good luck. That's just a few things I've tried so far.
Old Nov 13, 2011 | 07:42 PM
97CWITR's Avatar
Ill double check, and swap in a new sensor.
Wow! Hope you get it figured out man! Please keep me updated.
Hope I don't have to go through all that.
Old Nov 13, 2011 | 08:22 PM
NOFX's Avatar
H-T White Ops
I've got a thread in the EF section. Might make another one in tech later on. Think I forgot to change the fuel filter and maybe PCV valve when I got the car. One of those things where you have so many parts for multiple cars and if it didn't get done on the first day, then it got forgotten about.
*crosses fingers*
Best part is I'm supposed to put my Y8 into the car but just haven't had the time/help yet.
Old Nov 14, 2011 | 05:29 PM
Hey nofx. Your problem is pretty easy. If your cel is on for tps sensor and the car runs good without it plugged in, obviously the problem is with the tps circuit. Now, i don't know how much you know, but start with the basics.
Make sure the the sensor gets its 5volts reference. Then check that their is a good ground. Next check the return voltage. at closed throttle it should be at .5volts. wide open at 4.5volts. Many times the problems with the tps will be intermittent and you need a scope to see the problem.
If you get the proper voltage and the ground is good. Replace the sensor.
Old Nov 14, 2011 | 08:01 PM
NOFX's Avatar
H-T White Ops
I replaced the sensor and tested it. There's an obvious problem with driving but everything checks out.
I don't want to jack this thread so I made yet another one: "TPS" problem - Can't seem to solve
97civic07gsxr
Mar 27, 2009 05:11 PM
TeknikDC2
Jan 24, 2007 06:38 AM
dcfour
May 15, 2005 12:26 PM
mixmastabob
Aug 20, 2004 07:29 PM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
