1991 Accord SE Oil Filter Housing
Old Nov 12, 2011 | 07:43 PM
mrmelend's Avatar
Default 1991 Accord SE Oil Filter Housing
Hey forum....I purchased a 1991 Accord SE 4DR Auto a few months ago to restore but have fallen into a pool of problems. My recent major is the oil filter housing is cracked. I went to a guy parting his out but to my dismay it seems that this does not come apart how I thought. My question is this: is the oil cooler different than the oil filter housing? My local garage said the "oil filter housing is cracked" and I loose all my oil within minutes. I removed the filter from a 1990 accord lx w/ Manual tranny from a local guy parting his car out: is this where I went wrong? Honda dealer told me all accords, 90-93, were the same. I did not see anywhere to remove the oil filter "bolt" and the housing on this vehicle looked like it was intergrated into the block. Any help will be appreciated!
Old Nov 12, 2011 | 11:16 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1991 Accord SE Oil Filter Housing
Is part 22 what you are referring to?
15500-PT6-003 022 001 COOLER, ENGINE OIL (TSUCHIYA) 354.70 248.29
Verify that its not just a leaking gasket #33 or a loose 'bolt' #23. Not all cars have the oil cooler extension. If you cannot locate a replacement oil cooler, you may look into just deleting that part for now and using a standard oil filter 'bolt'(#24) to mount the filter directly to the block.
Old Apr 27, 2013 | 03:27 PM
Mishako129's Avatar
Sorry if this is an old thread but im bringing it up again. I want to install an oil cooler from a prelude in my 91 LX but I am having the hardest time finding the right size nuts to pull the oil filter stud out. I tried looking for axle nuts but can't find the right one. Someone said a VW axle nut can be sued but never said which one. Does anyone know what car it was?
Thanks.
Old Apr 27, 2013 | 04:56 PM
GhostAccord's Avatar
You don't use nuts to pull it out. You use a wrench and socket to remove the center bolt of the oil cooler housing. Why would you look for an axle nut...measure the head of the bolt you need to remove and get the proper sized socket.
30mm seems to ring a bell!
and confirmed with a 5 second Google search.......
Old Apr 27, 2013 | 05:32 PM
Mishako129's Avatar
Sorry for leaving out the details but I already removed the oil cooler at the junkyard with the 30mm deep well socket and now all I have to do is take out the non oil cooled oil filter stud from my block. I know for a fact the thread is 20mm, I found this axle nut on ebay that says its "20 mm" but I don't know if its the thread size or the nut size that its talking about (I sent the seller a message about it). Maybe you'll know, it says,
NOS ARCTIC CAT 3423-023 SPEEDOMETER / SECONDARY DRIVE NUT 20MM BEARCAT 375 400
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360623873074
Old Apr 27, 2013 | 06:12 PM
To be even more specific you are looking for a 20mm x 1.5 nut. Most times you see a metric nut/bolt being sold. They are designated by thread size and pitch, not the socket size.
So yes that is a 20mm nut, but weather or not it is a 1.5 or 1.0 thread pitch is not noted on the item description. You will have to ask the seller what it is. If they are not 1.5 you will have a hard time getting two of them on there and lock.
WingedMan
Aug 22, 2011 06:50 PM
PREACHERBREW
Mar 23, 2007 09:39 PM
alexsracing
May 18, 2006 09:47 AM
lv6l
11
Jan 10, 2006 05:47 AM
newhondaowner29
Aug 27, 2004 12:55 PM
