which cap and rotor?
Old Nov 12, 2011 | 07:25 PM
delsolo95's Avatar
Default which cap and rotor?
ok dumb question..
i have a distributor that is stamped TD-81U which from my findings is a 99-00 Si DOHC Civic. i have an OBD1 GSR engine and trans in my 95 del sol, when i compare pt# at autozone it says the 1995 GSR cap and rotor will not fit the 99-00 Si and vice versa.
so what do i get? the 99-00 si cap and rotor (since the distributor housing is TD81U) or the 95 gsr. i must be overlooking this but...
Old Nov 12, 2011 | 07:32 PM
98civdx's Avatar
Master Detailer
Default Re: which cap and rotor?
Well if you have the b16a2 distritbutor, go with the parts for it. This is what I would do.
Also, go with OEM, not that autozone stuff.
Old Nov 12, 2011 | 07:39 PM
delsolo95's Avatar
yeah oem i know i just didnt want to buy oem and it was the wrong one then theyll charge me a restocking fee you kno..
also the distributor i mentioned has obd 1 plugs how is that if its from an 99-00 si ??
Old Nov 12, 2011 | 07:45 PM
98civdx's Avatar
Master Detailer
ah, I understand.
Hmm good question. It is possible to swap the guts of it to the other.
Old Nov 12, 2011 | 07:49 PM
delsolo95's Avatar
yeah just wanna make sure. im going to buy a 99-00 si cap n rotor at autozone first if it fit my dizzy then ill refund and buy oem
Old Nov 12, 2011 | 08:05 PM
98civdx's Avatar
Master Detailer
I was just going to say that.
Pull your old stuff and compare it. See if there is any numbers or identifing marks on it.
Old Nov 13, 2011 | 08:16 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Cap and rotor from 99-00 Civic Si:
#2 in pic = Cap - 30102-P54-006 ($17.34)
#3 in pic = Rotor - 30103-P08-003 ($15.82)
I took this from HONDA AUTOMOTIVE PARTS.COM <-- Clickable
Don't get Autozone CRAP parts please. You walk into a dealership with the part numbers and there is no doubt that your parts will fit, and thus not need to be returned. Or order them from the link I just posted. Hell print screen the page and your local dealership will likely match the prices I just listed if you print screen the actual page from the website I linked.
Old Nov 14, 2011 | 07:19 AM
delsolo95's Avatar
thankyou b18c5eh2 i know how to look for a diagram my question was what cap and rotor to get since i have a gsr motor in my 95 sol which is obd1, weird thing is it has a b16a2 dizzy with obd1 plugs. thats what got me confused on which cap and rotor to get. kno what im saying?
Old Nov 14, 2011 | 11:29 AM
Wrona's Avatar
What i would do is go to a Orileys or autozone grab a distributor cap and rotor for a Si see if it fits and if it does return it and get OEM just to make sure
Old Nov 14, 2011 | 11:36 AM
kyden's Avatar
si cap and rotor. it doesn't matter if you have an obd1 or 2 distributor, since there is nothing different with the cap and rotor.
Old Nov 14, 2011 | 01:19 PM
delsolo95's Avatar
ummm....i did say that gsr and si cap and rotor are different as well as pt # so what are you saying?
Old Nov 14, 2011 | 01:20 PM
delsolo95's Avatar
anyway i will buy an si cap and rotor frm autozone to check if it fit my dizzy housing. hopefully it will fit
Old Nov 15, 2011 | 05:08 AM
kyden's Avatar
i was saying an obd1 gsr vs obd2 gsr is the same cap. so obd1 b16 and obd2 b16 are the same cap.
so get a 99-00 si cap.
trevek10
May 21, 2011 07:13 PM
itsJDMyo
Aug 11, 2009 05:43 PM
Jdmglenn
Dec 17, 2007 09:11 AM
ek2k
Oct 18, 2004 08:29 AM
