2004 Civic Power Window Switch
Old Nov 12, 2011 | 04:36 PM
RV Tech's Avatar
Default 2004 Civic Power Window Switch
Hi - Just bought a 2004 Honda Civic Couple EX and the passenger door power window switch does not operate the window. No click, just silence.
The window goes up and down fine from the passenger window switch that is mounted on the drivers door.
Bad passenger switch?
Is it possible that the Master switch on the drivers side could cause this?
I do not know how this is wired.
I do have the slave (Passenger) switch out and their is continuity though the switch from terminals 1&4 and 2&3 when the switch is idle. Continuity through 1&4 and 2&5 when the switch is in the window down position. Continuity though 2&3 when the switch is in the window up position.
I numbered these by looking at the terminals starting with number 1 on the left. I do not know if that indicates a faulty or good switch.
Any suggestions will be greatly appreciated. - Thanks
brent_si
Honda Civic (2006 - 2015)
Sep 18, 2014 09:11 AM
mayurji1
Jun 9, 2014 03:49 AM
builthatch
May 29, 2012 09:38 AM
ChicagoMike
Mar 14, 2006 08:07 AM
ExiledinIN
Apr 19, 2005 05:52 PM
