why is fire coming out of my intake
Old Nov 12, 2011 | 03:14 PM
Circaskaterr's Avatar
Default why is fire coming out of my intake
i have a da and i swapped a b20 and i crank it over and it runs but it misses and fire comes out of a hole in my intake
Old Nov 12, 2011 | 03:20 PM
lazlong's Avatar
Default Re: why is fire coming out of my intake
Blow-by can be caused by a lot of things- bad rings, valves, carbon buildup, something in the emission system. Try a top-end cleaner and pull the codes.
*Don't drive it like that or you'll need a new engine.
Old Nov 12, 2011 | 03:21 PM
DirtyDA9's Avatar
Your having an intake valve stick open and the gases are going back to your intake and the combustion is traveling out through your intake.
Old Nov 12, 2011 | 03:26 PM
Timing seems to be on point, so i don't think it is that but it is the thing that has been altered. It sounds better at higher RPM like it isn't misfiring at all. It's just a pop here and there at idle
Old Nov 12, 2011 | 03:30 PM
cetcivic's Avatar
no one wants to hear the truth
"FIRE IN THE HOLE!!!!
Old Nov 12, 2011 | 04:10 PM
Could it be something with the dizzy? It was fine before we transferred it over. The plug wires are in the right order, the timing is *right* the only problem could be that the motor was sitting for awhile, and there are a couple sensors unplugged/possibly not working
Old Nov 12, 2011 | 06:12 PM
DirtyDA9's Avatar
it will have nothing to do with the distributor. Everything the other guy said about the blow by is correct, listen to what he has to say. One of those is the cause. And valve timing wouldn't be a reason a valve is sticking open. So your timing could be dead on and still have a valve sticking.
Old Nov 13, 2011 | 12:44 PM
fcm's Avatar
fcm
Old Fart
Could also be as simple as a lash adjustment all it would take is one exhaust valve adjustment too tight, [valve stays open a little] "fire in the hole" 94
Old Nov 13, 2011 | 09:45 PM
hatmanafro's Avatar
fcm ftw
94lsrhd
Jun 13, 2009 05:55 PM
mkcivic
Jun 17, 2007 05:26 PM
Probot
Apr 17, 2007 09:53 AM
Slider89
14
Feb 2, 2005 04:08 AM
FrankensteinCRX
Apr 3, 2004 07:31 PM
