No electrical power help
Old Nov 12, 2011 | 02:57 PM
4dr_Noob's Avatar
Default No electrical power help
Replaced alternator and I have 0 power no lights. Nothing I'm working on it ATM if u got something and I took off the positive cable when I was working not the negative ....
Old Nov 12, 2011 | 03:11 PM
vartok's Avatar
Default Re: No power help
have you tested the battery?
Old Nov 12, 2011 | 03:12 PM
4dr_Noob's Avatar
No but it was good like 2 hours ago before I did alternator I'll check now though
Old Nov 12, 2011 | 03:18 PM
4dr_Noob's Avatar
I don't have a Damn multimeter lol
Old Nov 12, 2011 | 03:42 PM
4dr_Noob's Avatar
I hooked the battery charger up it doesn't look to be full charged I think I should start tere I guess but I figured I'd still get the lights in the dash to come on since it did when it die over night hmmm
Old Nov 12, 2011 | 03:46 PM
4dr_Noob's Avatar
Oh and if it is dead wouldnt the starter on the battery charger still start me ?
Old Nov 12, 2011 | 04:47 PM
4dr_Noob's Avatar
ok the battery is good what can it be?
Old Nov 12, 2011 | 04:52 PM
grumblemarc's Avatar
The Grumpiest
Did you check the grounds? You don't seem to be doing well with your car AT ALL.
Old Nov 12, 2011 | 05:48 PM
Wrona's Avatar
check the battery ground can you also stop posting every 2 MINUTES!!!! just edit your original damn post and go from there
Old Nov 12, 2011 | 05:52 PM
4dr_Noob's Avatar
tell me about it lol it ran perfectly fine till i ****ed up the valve cover all this for painting the valve cover lol and no the ground cable is good
Old Nov 12, 2011 | 06:41 PM
Wrona's Avatar
you must of touched something else than the valvecover i had thesame thing happen to my car the ground for some reason F-d up and i had to sand part of the paint off and now it works and it just did it randomly
Old Nov 12, 2011 | 06:59 PM
4dr_Noob's Avatar
i think i might have shorted something out though cause i took the posative terminal off instead of the negative
Old Nov 12, 2011 | 07:09 PM
4dr_Noob's Avatar
oh wait when ur ground was messed up it made nothing work at all not even even any lights at all came on?
Old Nov 12, 2011 | 08:37 PM
Wrona's Avatar
nothing it was random i parked the car came out 2 hours later thought my battery died my friend jumped it for 30 minutes nothing at all came on i pushed down on the battery ground and the car started working inside so i removed my fusebox sanded down a little area and put my ground under the fusebox screwholes the battery ground would be a perfect explenation why nothing is working also the battery fuse
Old Nov 12, 2011 | 10:49 PM
4dr_Noob's Avatar
ill re check the ground 2 maro and the battery fuse looked good u can tell if its bad just by looking at it correct since it has a see through top?
Old Nov 13, 2011 | 05:41 AM
Former User's Avatar
Please create more descriptive thread titles. "No power" could mean a lot of different things. You meant no electrical power. Title edited.
Test the 80A hood fuse.
And buy an inexpensive multimeter.
Old Nov 13, 2011 | 06:09 AM
4dr_Noob's Avatar
Default Re: No electrical power help
ok will do and sorry for bad title
Old Nov 13, 2011 | 06:11 AM
4dr_Noob's Avatar
ohh you changed it thankyou i was about to so i dont know how
Old Nov 13, 2011 | 07:20 AM
Jimster480's Avatar
soundsl ike a grounding issue.
Multimeters are only a few $ at harbor freight, and they arent even expensive at major retailers anymore
Old Nov 13, 2011 | 07:52 AM
4dr_Noob's Avatar
like autozone? lol ive never herd of harbor freight lol
Old Nov 13, 2011 | 07:54 AM
The Grumpiest
http://www.harborfreight.com/
Just get one. Automotive, home repair, Big Lots. You can get one anywhere.
Wrona's Avatar
http://www.harborfreight.com/ky.html
closest one to u is lexington
Old Nov 13, 2011 | 08:09 AM
I think the Harbor Freight Tools multimeter is currently on sale for $2.
Old Nov 13, 2011 | 08:15 AM
4dr_Noob's Avatar
2 dollars lol thats a little costly ima get one from a local store so i can use it today but i didnt know harborfreight was online thank you!~
Old Nov 13, 2011 | 10:05 AM
4dr_Noob's Avatar
ok its definatly not the ground
