Car Wont Drive?
Old Nov 12, 2011 | 08:27 AM
98CoupeE's Avatar
Default Car Wont Drive?
so last night when i was out my car didnt want to go into gear while the car was running, if i turned the car off i could put it in gear and drive or w/e. this morning when i went to turn on my car the clutch pedal was all floppy and the car started shaking and trying to go forward when i turned it on, aswell i couldnt put it into gear once i took it out. now the clutch is floppy and the car creeps forward with the clutch all the way in while its in gear and i still cant put it in gear when the cars on, sometimes i can get the revs right and bang it into gear but thats about it. if anyone knows what could be wrong/going on it would be greatly appreciated, thank you.
car is a 1998 honda civic coupe with stock d16
Old Nov 12, 2011 | 09:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Car Wont Drive?
Clutch slave cylinder.
Old Nov 12, 2011 | 11:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I'd clarify and say you need to check the clutch master cylinder (under your dash at the top o your clutch pedal) AND the clutch slave cylinder for any fluid leaks. I'd replace them BOTH if I were you.
mrcoolhead
Jan 30, 2013 06:12 PM
codybb4
Dec 9, 2008 08:44 AM
scrEaMO Kyle
Nov 3, 2005 11:49 AM
Luchini
Oct 16, 2005 11:15 AM
hybrider
18
May 9, 2002 08:08 PM
