Fuel Injector Miss Fire !
Car Info- 92 si civic hatchback
Motor- D16z6
Issue- Miss Fire in fuel section.
I had to do a Intake Manifold swap on my car because it broke some how on the water port side.
Long story short i did the swap and when i swapped out the injectors 1 of the o-ring seals broke so it leaked gas,
Swapped it out with new ring, retighten , still leaked, i then keept tightening the fuel rail bolts , heard a pop then the 1 injector stoped leaking, now the car runns like a miss fire 50/50 of the time other times just rough.
Did i brake the injector?/?
How can i fix this problem???
Thank
Motor- D16z6
Thank
i would suggest you look at the color of wires going to the injector all of them have yellow wires but from cylinder 1 (cam gear side)----->brown, red, blue, yellow----->to dizzy
thanks jrp will do.
And i am going to swapp them out wuth 440cc to double check with a friend of mine.
Thanks all
But i think this is the real problem to my question look pls LMK ..https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/radiator-fan-stays-w-o-direct-wired-2999911/
Thanks
Thanks all
Thanks
