Installing Injector Clips - Help Needed!!!
Old Nov 14, 2005 | 11:46 PM
Dan_the_MaN's Avatar
Default Installing Injector Clips - Help Needed!!!
My car is a '97 Civic LX with D16Y7. I am installing new injectors with new clips. So I got to the part of taking everything out, put the new injectors into place. Now, the new injector clips I have are just the clips with two wires coming out of the other end. I have the old injector clips with two wires also coming out of the end, still on my car. How do I connect the new injector clips?
Do I just cut the wires to the old clips and splice the wires of the new clips onto them? Please Help!!!
Old Nov 15, 2005 | 01:41 AM
Default Re: Installing Injector Clips - Help Needed!!! (Dan_the_MaN)
Ok, I just read a thread about splicing wires, so I went ahead and did that. Now I am having a problem with a fuel leak. I installed the injectors and reassembled everything back together. I made everything extra tight as well. When I start my car, fuel start leaking out at the top of the fuel rail. I think its at the fuel return line connection. I tightened it and it still leaks fuel. The car starts, but it sounds like its about to die. When I press the throttle, nothing happens. I am guessing its because there is no fuel pressure. The fuel spills out when I turn the key two clicks as well, the click right before you start the engine.
Do you think the injectors are not working?
I reassembled the fuel rail wrong?
Suggestions?
Old Nov 15, 2005 | 04:45 AM
DannyDeuce's Avatar
What kind of injectors do you have?
Did the injectors come with the rubber o-rings? Don't install them without the o-rings.
Did the injectors fit snug in the fuel rail. Usually with aftermarket injectors, the rubber o-rings are usually a little too big which causes them not to fit into the fuel rail properly.
DAN
Old Nov 15, 2005 | 08:33 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan_the_MaN &raquo;</TD></TR><TR><TD CLASS="quote">I made everything extra tight as well. When I start my car, fuel start leaking out at the top of the fuel rail. I think its at the fuel return line connection. I tightened it and it still leaks fuel. The car starts, but it sounds like its about to die. When I press the throttle, nothing happens. I am guessing its because there is no fuel pressure. </TD></TR></TABLE>
did you put the washers back on either side of the fuel feed banjo fitting?
can you post a picture showing where it leaks from?
did you re-tune your car for these injectors (assuming they're bigger than you had before)?
Old Nov 15, 2005 | 02:35 PM
Default Re: Installing Injector Clips - Help Needed!!! (notoriousB)
Ya, I bought a chipped ecu from phearable.net with the bigger injector size as specs. I put all the washers back in. The fuel feed banjo, what is this? If your talking about the main fuel line going into the fuel rail, then yes, I did put two washers back into it. I'll post up some pics soon.
goldex420
Sep 6, 2013 10:32 PM
scamp91ex
Jan 9, 2013 06:36 AM
Stick2swishers
Nov 1, 2010 06:33 AM
90Rexx
Dec 1, 2008 06:08 AM
Turbo-Honda
Jun 30, 2004 09:39 PM
