CLUTCH F*@#$d?
Old Oct 6, 2002 | 08:36 PM
pr0jektdc2's Avatar
Default CLUTCH F*@#$d?
my clutch went out on the street..i just got off the freeway and i was about half a block down and i put my car in neutral and it wouldnt go into any other gear after!?!? i pulled over and turned off the car and tried shifting...it went in without a problem..so i put the car in first and turned it on...and the clutch was all the way down and it felt as if it wouldnt hold anymore... i heard a funny noise coming from the engine bay but only when it was in a gear... when i put it in first and started the car it wouldnt go back into neutral so i just turned it off and got the car towed home... my friend came in his crx and said it was my clutch fluid but when i popped the hood i didnt see a clutch fluid resrvoir!?!? is my clutch fvk'd? and how much am i looking at to have a new one installed at a shop..and no im not gonna try to install it myself!!!!!! THANKZ TO EVERYONE FOR READING!!!!! im under alotta stress cuz i have no comuter to werk and school....
oh yeah this is for a 94 LS
[Modified by pr0jektdc2, 5:37 AM 10/7/2002]
Old Oct 6, 2002 | 08:48 PM
jonoknut's Avatar
Default Re: CLUTCH F*@#$d? (pr0jektdc2)
well the fluid is right under the hood, but my clutch is going and i got quoted from a few people, this garage wants 700 fro everyhting parts and install on a stock clutch. They said they wouldnt do an isntall for an aftermarket one due to liability. I went to honda and they wanted 1150 for everyhitng. thats quite pricey. so im just buying one online and having a friend put it in for me for pretty cheap.
Old Oct 6, 2002 | 08:51 PM
pr0jektdc2's Avatar
Default Re: CLUTCH F*@#$d? (jonoknut)
where rite under the hood...would it be the 2 reservoirs in the back right...the small one and the big one?? i always thought it was thebrake fluid and ABS fluid!?!? please elaborate
[Modified by pr0jektdc2, 6:12 AM 10/7/2002]
Old Oct 6, 2002 | 09:13 PM
pr0jektdc2's Avatar
Old Oct 6, 2002 | 09:18 PM
MugenGTR's Avatar
haha, same happened to me. anyways, try import builders, they hooked me up w/ a cm stage 4 w/ installation for sumthin like $450 i think, it's been awhile, can't remember. my clutch is freakin krazy! anyways, also hella recommend prospeed also and maybe holeshot
Old Oct 6, 2002 | 09:34 PM
pr0jektdc2's Avatar
Old Oct 7, 2002 | 05:47 AM
Rory Breaker's Avatar
Do you see clutch fluid underneath your clutch pedal?
You would be looking at the small reservoir...it should be filled with fluid with a small plastic stopper floating on top.
Old Oct 7, 2002 | 12:14 PM
GripFactoR's Avatar
Default Re: CLUTCH F*@#$d? (newgsrdriver)
the clutch fluid reservoir is the small one on the back right....
u can see where it goes into the firewall... and if u look under the dash
you can see where the clutch connects to...
check the fluid...
Old Oct 7, 2002 | 12:21 PM
shipsaeki's Avatar
Default Re: CLUTCH F*@#$d? (MugenGTR)
I doubt you got a clutch master stage 4 for $450 including installation. anyways, I just put in a clutch master stage 3. the clutch alone was $522.00 and I also had a clutch master lightened flywheel, but installed a new excedy flywheel. the total came out to 1100. But thats because I chose not to resurface my flywheel and get a new one. Your looking to spend anywhere from 600-900 installed w/o a new flywheel and just using your current one.
[Modified by shipsaeki, 12:53 AM 10/8/2002]
Old Oct 7, 2002 | 12:46 PM
SPOON_BeIgHtEeNsEe's Avatar
i have a ITR clutch and ITR flywheel if ur interested... IM me...
Old Oct 8, 2002 | 03:57 PM
pr0jektdc2's Avatar
okae form what i described i need to know if anyone has had this same problem...or does anyone think its my tranny...when i put the car in a gear and start it i can feel it only grab at the verrryyy bottooom of engaging the clutch!?!? i doubt its my tranny b/c it will shift into any gear when the cars off but when the cars on it wont shift into any gear except for the one its in TIA!!!!!
pr0jektdc2's Avatar
TTT!!!!!!!
Old Oct 8, 2002 | 04:01 PM
Tomakit's Avatar
You broke a spring on the clutch disc.
EXACT same thing happened to me. I drove home in 2nd gear, ~5miles...ebrake as brakes...left foot constantly holding the clutch down, right foot on gas, 60mph.
gf loved that one.
Tom
Old Oct 8, 2002 | 04:06 PM
pr0jektdc2's Avatar
Default Re: CLUTCH F*@#$d? (Tomakit)
gf loved that one.
Tom
thanks Tom i owe yah one...so im guessing u bought the whole clutch kit and had it installed...how much is a good price for installation...liek i said im not even going to dare try install this...my uncles shop is willing to do it for 200 [labor only...] is taht a good price considering all the **** they have to take out
Old Oct 8, 2002 | 04:09 PM
Tomakit's Avatar
200 is a very fair price for clutch labor.
Tom
dexy
Jan 11, 2005 09:53 AM
dexy
Jan 10, 2005 10:17 AM
just4747
28
Dec 5, 2004 11:30 AM
MiraiZ
Aug 12, 2003 06:18 PM
