97 civic ex cruise control don't light up or work
Old Nov 11, 2011 | 02:20 PM
mrprofits1's Avatar
Default 97 civic ex cruise control don't light up or work
like the title says. i have taken out the cruise control and clean it , it was so dusty, i also check that the wires are intact and not loose. i also checked the cruise control fuse#14 and it's fine.
i dont know how to set the cruise control either, i press the button then start the engine? it might be that i don't know how to use it or it doesn't works and i need help from you guys/gals.
btw what vacuum line connects to the back of the manifold? i check and it was nothing there and connected the vaccum line from a canister on the driver side top corner to the manifold.
EDIT: also my car does not have a airbag in the steering wheels forgot to mention
Old Nov 11, 2011 | 03:22 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 civic ex cruise control don't light up or work
What do you mean you took out the cruise control to clean it? I have never heard of anyone ever having the need to do such a thing.
Was it working BEFORE you cleaned it?
Car on. Drive. Press cruise control button and it should light up. Achieve desired speed. "SET". Remove foot from accelerator. If cruise control is working car will maintain the speed you set. You can then use the controls on the steering wheel to accelerate or decelerate. Drive to automotive store and purchase car manual appropriate for your make/model. To disengage cruise control step on brake/accelerator or turn off cruise control.
Old Nov 11, 2011 | 03:28 PM
z0mby's Avatar
+1 Lol.
Old Nov 11, 2011 | 07:24 PM
mrprofits1's Avatar
Car on. Drive. Press cruise control button and it should light up. Active desired speed. "SET". Remove foot from accelerator. If cruise control is working car will maintain the speed you set. You can then use the controls on the steering wheel to accelerate or decelerate. Drive to automotive store and purchase car manual appropriate for your make/model. To disengage cruise control step on brake/accelerator or turn off cruise control.
i shouldof explained myself better. i took the cruise control buttom/switch out and check the wires to make sure they were not loose i also cleaned it with qtips since it was dusty just to take the dust away.
no it wasn't working when i cleaned it. i pulled it out to see if it was connected or if it had loose wires but everything looks fine.
i have tryed what you said and it doesn't light up.
Old Nov 12, 2011 | 03:27 AM
The Grumpiest
It doesn't light up. Is it working? I could care less about the light.
Old Nov 12, 2011 | 04:06 AM
vartok's Avatar
For the moment lets just assume the light doesn't work.... Get going more that 40mph (won't work any slower that that)..... Be on the safe side and make it 55. and hit the set button and let off the gas... If you slow down more than 5 mph, it didn't enguage (these cruse controls are a bit sluggish compared to other cars). Hit the cruse control button on the dash and try again. If it still doesn't work then there really is something wrong with it...
Does your horn work and does your srs light come on and stay on? If so, the cable reel is broken.
Old Nov 12, 2011 | 02:53 PM
mrprofits1's Avatar
it doesn't light up nor work the way you told me to do it.
Old Nov 12, 2011 | 02:54 PM
mrprofits1's Avatar
i will def try this. and will come back to report in.
my horn does works, my srs light is on and does stay on. where is the cable reel?
thanks.
Old Nov 12, 2011 | 04:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
The cruise control button on your steering wheel gets it's power from the CABLE REEL (also referred to as a "clock spring" by salvage yards) and when you said you're missing your airbag I'll bet you're also missing the cable reel, or it's broken/damaged internally.
Cable reel can be seen here - #2:
Do you have a aftermarket steering wheel? Maybe someone hard wired the horn?
Old Nov 12, 2011 | 04:43 PM
The Grumpiest
Lord. I wish you would have said you removed the airbag in the first post. You edited that in MUCH later I see. Would have helped up front to avoid all this confusion.
Old Nov 12, 2011 | 10:15 PM
mrprofits1's Avatar
hello thanks for the help. i don't have an aftermarket steering wheel.
Old Nov 12, 2011 | 10:16 PM
mrprofits1's Avatar
never thought it might be some how related this is my first honda im not familiar with them
Old Nov 12, 2011 | 10:19 PM
mrprofits1's Avatar
well im here to report in just like i said i was.
i did what you said but rolling at 25mph and bang i was able to turned on my cruise control it works thank you very much!
Old Mar 24, 2012 | 06:02 AM
pintobean11's Avatar
Bump!
My cruise control doesn't work and my SRS light is on. I see the diagram up top showing the cable reel. I'm assuming that is located behind the steering wheel?
How could this go bad and how hard is it to replace?
Old Mar 24, 2012 | 06:24 AM
Former User's Avatar
What car? Pull the SRS code. Is the code for the driver's airbag?
Old Mar 24, 2012 | 09:17 AM
It's an LX, I have not not pulled the code so no idea if it's driver or passenger.
Old Mar 24, 2012 | 09:28 AM
The Grumpiest
Might wanna do that dontcha think?
Old Mar 24, 2012 | 11:29 AM
Can't that only be pulled at a dealer?
Old Mar 24, 2012 | 11:31 AM
What year Civic LX???
For 6th gen Civics, you just need to jump the service connector and read the blinking SRS light. See FAQs sticky.
Old Mar 24, 2012 | 01:18 PM
1996....
Old Mar 24, 2012 | 01:20 PM
The Grumpiest
Are you acting helpless on purpose? Did you jump the service connector?
Old Apr 30, 2012 | 04:39 PM
Update, I was able to reset the SRS light but the CC still doesn't work. I replaced the brake pedal switch with a rubber stopper so it's tall enough. Can't figure out why else the cruise control doesn't work.
cloud2kz
Aug 26, 2009 11:13 AM
turbodelsolb16a2
10
Dec 28, 2008 01:41 PM
wwmost
Mar 26, 2008 05:19 PM
noble4ws
Aug 16, 2004 02:24 AM
