B20 EG idle problems....
Old Nov 11, 2011 | 01:29 AM
924doorEG's Avatar
Default B20 EG idle problems....
hey guys, so i have a issue with my b20 eg...i recently swapped it in around spring in warm weather....i realized my map sensor was bad when i did the swap, so i disconnected the map, and im not running a o2 nor am i running practicly any of the sensors on the maifold....Anyways, so it swapped in fine, runs great off a basmap chipped p06, and as it started to get to cold weather, or maybe i didnt noticed right away but now the car idles around 2000 cold at start up....and slowly fades itself down to about 1100 or 1200 when warm.....Back when i first swapped it in it ran at around 900-750 depending on the day because theres nothing hooked up basicly....is that my issue? or could it possibly be somthing else? if you guys can help it would greatly be appriciated!!!!! thanks guys.
Old Nov 11, 2011 | 01:57 AM
First.EG's Avatar
Default Re: B20 EG idle problems....
those sensors are there for a reason dude.
Old Nov 11, 2011 | 03:17 AM
BryanM.'s Avatar
Resident Gearhead
I'm not trying to be an ****ole, but why don't you think that could be the cause?
Hook up everything correctly, see what happens. The TPS, MAP and IAT sensors are very important.
Old Nov 11, 2011 | 04:14 AM
grumblemarc's Avatar
The Grumpiest
Wow.
Old Nov 11, 2011 | 02:01 PM
924doorEG's Avatar
yes they are important.... but i need to get a ls manifold because im still running the b20 maifold and thats the problem i havent had time nor have i had the $$$....but im hooking up a new manifold once i get some cash flow....but i was just curious because why would it just have all of a sudden just started idleing high, but fr the last 6 months it has been pefectly fine?.....
Old Nov 11, 2011 | 05:26 PM
924doorEG's Avatar
anyone else or you all just gonna say hook up all the ****in sensors?
Old Nov 11, 2011 | 05:27 PM
The Grumpiest
Yeah. Hook 'em up.
JDMswagSerf
Feb 7, 2016 02:50 PM
efkilla
Aug 28, 2014 10:09 AM
salyboy25
Jun 8, 2011 11:47 AM
si90rex
Engine Management and Tuning
May 22, 2010 10:35 AM
95GSRDC2
Sep 5, 2007 02:39 PM
