143 WHP? 02 rsx-s
i just performed 3 pulls on a mustang dyno and my best results were 142.8 hp at 6770 rpm and 121 torque at 4200. I have a aem short ram, dc header and skunk 2 cat back.
I expected to see around 170-180 hp at like 8000. the front firewall and radiator motor mounts are cracked but as far as i can tell that's the only thing wrong with the car. it goes through a quart and a half of oil in 5000 miles but i think that's typical
what do you guys think?
you know what? i just noticed that the map reading is 9 in Hg at that point i was on a closed throttle decel before my next pull. under those conditions I should be 18 or better...either the machine is wrong or i have a serious vacuum leak.
Surprised you didn't do a 3rd gear pull being stock N/A instead of a 4th gear.
But if you want to double check your engines health do a compression test and tell us your numbers.
i plan too... 3rd gear? I did this at my college, we have a dyno there. every one was doing 4th gear from 60 to 100ish. I have never done it before so i didn't question them. I'll have access to it again in the future, net time i'll use 3rd.
http://www.youtube.com/watch?v=R4ebts0pcNE
Dyno Chat
Thats my dyno pull on a mustang dyno. I made 174 WHP and 122TQ with a Spoon Sport Street Axle back muffler, Stock air box with Spoon Sport drop in fiter, and Spoon grounding kit. On the same day a completely stock 08 Civic pulled 169WHP. Was everyone elses numbers reading low? It could very well be a low number caliberated dyno.
Dyno Chat
It could be many things... I would try again in 3rd gear!
Also get a compression test done... also I'm sure you used 91 octane? I'm throwing it out there because I don't know if you just got the car or what... But if 87 octane was used the computer would detune the engine so no further damage could be done!
2000vsm
Oct 11, 2003 10:33 AM
