Dyno pulls?
Old Mar 28, 2003 | 04:50 PM
typer 00-115's Avatar
Default Dyno pulls?
What gear have most of you guys dynoe'd your cars in? I did mine in fourth everytime I have gone, but today my friend did it in third and fourth and third made 4-5 more WHP. It seems to me that you should dyno it in the gear it makes the most power in. This has probably been talked about a billion times, but so what we should do it again it's fun.
Old Mar 28, 2003 | 04:58 PM
Eric R's Avatar
Default Re: Dyno pulls? (typer 00-115)
On the ITRs, it's usually done in 3rd gear but, I've seen ppl using 4th gear as well.
Old Mar 28, 2003 | 05:51 PM
PM-Performance's Avatar
Default Re: Dyno pulls? (Tweety R)
i have always made more power in 4th. 4th is more of a 1:1 ratio.
Old Mar 28, 2003 | 05:54 PM
Dr Pooface's Avatar
Default Re: Dyno pulls? (itr206)
You're not "making more power".
Old Mar 28, 2003 | 06:07 PM
Default Re: Dyno pulls? (Dr Pooface)
well it sure as **** shows it to me .as far as syno purposes in hondas, 4th is better, i have proved that over and over again .
but i dont know much , i have only dynoed on those hp calculators.
Old Mar 28, 2003 | 06:08 PM
Dr Pooface's Avatar
gearing has nothing to do with hp.
Old Mar 28, 2003 | 06:15 PM
like i said before , i nver really dynoed, just play with the hp calc
Old Mar 28, 2003 | 06:28 PM
YelLowITR's Avatar
4th is the closest one i guess, but mine was dyno with 3rd
Old Mar 28, 2003 | 06:44 PM
92TypeR's Avatar
FSAE
Default Re: Dyno pulls? (YelLowITR)
I've done fourth gear pulls every time. Like mentioned above its closer to 1:1.
Old Mar 28, 2003 | 07:21 PM
Dr Pooface's Avatar
Sorry, I'm confused.
but in the other thread you say:
always do it in 4th , i have proof that my car made more power in 4th, and actually got into an arguement with the guys at the Dyno contest at NOPI, and proved em wrong , they said 3rd is better. . ..i told em i was pretty sure i knew my car better then that . . . . that got me a trophy at the contest too .
What did you get the trophy for? Calculating your hp on a program?
Old Mar 30, 2003 | 10:13 AM
i was joking. its apparent i dont know anything ,. so i just said i never dynoed and only played with hp calcs
Old Mar 30, 2003 | 10:43 AM
Rboosted717's Avatar
On a boosted car you will make more power in 4th gear because in a higher gear you will boost slightly more. I have seen a 5-8whp gain when dynoing in 4th on my JRSC setup.
However you should be looking at the whp, trq, and AF curve rather then the peak numbers.
However running the car in 3rd is will give a cleaner reading because in higher gears the dyno will start to pick up interference and the curve will start to degrade and because choppy.
Cyber ITR
Sep 11, 2008 06:43 PM
kito858
Honda S2000
Dec 16, 2006 04:14 PM
racinskittle
Jan 24, 2004 11:58 AM
2000vsm
Oct 11, 2003 10:33 AM
typer 00-115
Mar 29, 2003 11:35 PM
