Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Funny brake noise
Old Nov 9, 2011 | 05:17 AM
DaveSi677's Avatar
Default Funny brake noise
I have this annoying sound coming from the brakes on my FA5. Basically sounds like they are squeaking as if they were finished. The pads still have about 60% life on them.
My mechanic tried to clean the pads by removing the accumulation of junk in the little cut the pad has in the middle. Still hasn't taken care of the issue!
Has anybody had this situation?
Also what pads are you guys running?
Old Nov 9, 2011 | 06:29 AM
Sleepy_Red_hatch's Avatar
Default Re: Funny brake noise
aftermarket whitebox pads? try honda pads, i find the cheapie pads have big metal particles in them that squeel. also sometimes rocks between the dust shields and rotors will cause this too
Old Nov 9, 2011 | 06:40 AM
bee guz's Avatar
If someone bent the warning tab and it's touching the rotor it will give you that sound.
They are small metal tabs on the front brakes that are made to touch the rotor when the pad is nearly worn out, if one or both of the tabs are bent they will give you that sound long before the pad is worn out.
Check the tabs.
Old Nov 9, 2011 | 09:27 AM
DaveSi677's Avatar
Thanks for the quick replies guys... i will check the tabs... also the pads were on the car when I got it so it does have to my knowledge " generic pads"... when they are done i will be switch to either axxiss or hawks HP
Old Nov 9, 2011 | 02:16 PM
Theroy's Avatar
Check if the warning tab is bent for any reason. If you have ceramic brake pads on a metallic compatable rotar they could be over heating, and potentially tearing up your rotars.... or vice versa. Pictures of your brakes would be most handy.
Old Nov 10, 2011 | 05:26 AM
DaveSi677's Avatar
ill try to get some... im at the dealer right now getting my rack and pinion changed and I will be speaking to the mechanic later
Old Nov 10, 2011 | 08:58 AM
eundaddy's Avatar
did ur mechanic lube the back of the pads????
Old Nov 12, 2011 | 04:44 PM
DaveSi677's Avatar
yes they were!
PatrickGSR94
Suspension & Brakes
Jun 2, 2008 03:17 AM
93egSIboi
Feb 1, 2005 04:51 PM
dj626
Sep 30, 2004 01:12 PM
PatrickGSR94
Apr 13, 2002 09:42 PM
Floyd
Sep 18, 2001 07:29 PM
