Car won't START
Recently i let my girl drive my car then she stalled outt on a hill & it wouldn't start up so i let it roll & popped the clutch but ever since then it wouldn't start up unless i did a push start a jump start wouldn't work . It doesn't crank or anything but the fuel pump turns on and when its running it's fine with no problem but when i turn it offf it doesn't start unless a push start anyone know the problem ?
Some say the battery some say the alternator some say the starterrr but when i jst have the car on second click without it started all lights radio etc work finee & the battery is fairly new
More info? Car, year, engine, recent upgrades.
Check battery connections, and all 3 grounds, check all fuses(under-dash and under hood) check battery and signal connections at starter.
Its a 93 ej1 with a b20v swap no recent upgrades i recently bought it & everything was fine would start up but would crank a few times in the cold i'm thinking it might be the startter ima go test the battery & how would i know if it's not the alternator
If the car runs fine once it is started then the alternator is fine. You can test the battery and alternator yourself with a multimeter. You should have like 11-12 volts at the battery with the car off and about 14 volts with the car on assuming the alternator is doing its job. If you have less than 10 volts with the car off replace your battery. If both alternator and battery test good, replace your starter.
check the rubber stopper on the clutch pedal. if you turn the key and you get no click most likey that will be your problem. if its that just glue a penny over the hole the rubber stopper was in.
NiKKa NiKKy
Jun 30, 2022 09:59 PM
barnchips
Jul 19, 2013 11:34 AM
