1992 civic hatchback rear camber arm bolt wont tighten
Old Nov 7, 2011 | 06:00 PM
swizz977's Avatar
Default 1992 civic hatchback rear camber arm bolt wont tighten
i just put in a camber kit in the rear and one of the bolts wont tighten is there anything i can do?
Old Nov 7, 2011 | 06:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 1992 civic hatchback rear camber arm bolt wont tighten
Just spins around? Possibly you snapped off the welded nut on the inside. Make sure the bolt is correct size though.
Old Nov 7, 2011 | 06:24 PM
swizz977's Avatar
is there any way i cant get to that welded nut?
Old Nov 7, 2011 | 06:31 PM
The Grumpiest
I think there is some cutting involved.
Old Nov 7, 2011 | 06:37 PM
swizz977's Avatar
cutting the chasis? is there any other option i can do??
Old Nov 7, 2011 | 06:47 PM
swizz977's Avatar
its the rear upper control arm one of the bolts on the chassis wont tighten i think its nut stripped or might even of fell off behind if its welded on the back
Old Nov 8, 2011 | 12:59 PM
swizz977's Avatar
anyone else have this problem
Old Nov 8, 2011 | 01:54 PM
The Grumpiest
I've read that a few people have. I don't recall that they ever reported how they fixed it past opening up a hole to get to the nut.
Old Nov 8, 2011 | 01:58 PM
The Grumpiest
https://honda-tech.com/forums/showth...ber+bolt+broke
Old Nov 8, 2011 | 06:20 PM
apexi_rsx's Avatar
try one of these get the right size and pitch and waaaalahhh no welding or cutting. might have to drill the hole out a little to fit the insert or rivet nut sleeve in the hole. http://www.rivetsinstock.com/rivet47.htm
Old Nov 10, 2011 | 12:53 PM
swizz977's Avatar
where can i buy something like this locally
Old Nov 10, 2011 | 05:59 PM
swizz977's Avatar
also im pretty sure the gas tank is in the way of cutting to get to the nut no?
Old Nov 10, 2011 | 06:11 PM
98civdx's Avatar
Master Detailer
If the tank is in the way, then remove it.
I don't think it is, but it could be. Basicly your cutting out where the the bolt threads into to.
Old Nov 10, 2011 | 06:34 PM
swizz977's Avatar
if anyone knows wher i can get one of these in a m10 1.25
Old Nov 10, 2011 | 06:51 PM
The Grumpiest
In the other thread you're juggling someone supplied you with a link. Call them and ask.
Old Nov 11, 2011 | 08:06 AM
rhymeshark916's Avatar
You get it fix? I need a write up. I need mine fix.
Old Nov 11, 2011 | 08:18 AM
apexi_rsx's Avatar
how much more do you want me to do i gave u a link where they sell them... do you want a spoon to feed it to you or a plane ticket for me to install it too? come on now! its not hard to search ebay
Old Jan 2, 2012 | 06:37 PM
swizz977's Avatar
ok so everyone with this problem how did u fix it??
Old Jan 2, 2012 | 06:44 PM
The Grumpiest
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rear-upper-arm-bolt-question-1992-civic-3012427/
Old Jan 2, 2012 | 07:22 PM
Former User's Avatar
Please do not restart a topic that you have already beat to death. When you actually attempt some of the many fixes suggested to you, then create a new thread if they don't work.
stormdrop
Aug 24, 2012 06:05 AM
TekBuDDy
Mar 24, 2010 03:10 AM
MrDomino
Aug 10, 2007 09:05 AM
huge230
Nov 26, 2006 09:47 AM
blackdc5
Welding / Fabrication
13
May 9, 2006 11:21 PM
