1998 Civic EX - How to perform an alignment?
My tires are all at 35lbs, and the car pulls to the right. This has been a problem for a few weeks.
One thing I haven't done yet is rotate the tires to see if that helps.
If it doesn't ... How hard is it to perform a front-end alignment on this car? Tools required? Tips?
all cars should go to the right but not pull to the right. The reason being is if you fall asleep at the wheel or pass out the car will not go into traffic. I do not think this is in terms of alignment but more so the design of the car especially with FWD cars. Remember it should not be an instant right turn but more of something that occurs over distance.
lol. An alignment should not be set to pull right. The crown in the road will cause the car to drift right. That sounds like a silly excuse you would get from a shop after getting a bad alignment.
[voice=dopey]"Thanks for the money! Sorry your car still pulls!"[/voice]
All sorts of things can contribute to a pull in one direction.
- Road
- Uneven Tire pressure
- Uneven wear on tires
- uneven camber
- uneven caster
- uneven rear toe
A string alignment isn't all that difficult. You will need some thin fishing line, a good metric scale and a level for your scale. Also a tool to hold the steering wheel steady sure helps. And you will want to make slip plates out of glossy bags with a little grease or spray lube inside. You also need to know your front & rear track widths.
- Road
- uneven camber
- uneven caster
- uneven rear toe
I wouldn't doubt that although there are no crowns in NJ roads, we are happy when a road doesn't have a pot holes.
The string method works pretty well, I did it with some vice grips and a monkey wrench. An extra pair of hands doesn't hurt when you are first stringing the car up.
i am going to ask the best question because no question is stupid. Right??? heheh. now when you guys adjust the tow in and toe out... how do you access the tie-rod, because usually an alignment shop either has a trench or a lift so they can do adjustments under the car, with the car's weight on the ground / lift platform....
Then when it comes time to make adjustments, you just lay on your back and slide your arm under with a 14mm wrench. the inner tie-rod has a hex shaped section that the wrench fits. You can easily spin it in either direction. Just make sure your going the correct way, and then re-check your string measurements.
The toe itself is very sensitive to adjustments in the front. I could definitely measure the difference in 1/8th of a turn of the tie rod. Just be aware that if you go a little too far, there is a small moment when backing up the tie-rod makes no adjustment. This is because the outer tie-rod rolls the opposite direction at first until it runs out of travel. Took me a while to figure this one out why it make a large change in one direction, then no change in the other... lol
Wow! It's been a few days since I was here.
No, it's not a torque steer issue, or a road grade thing. It will pull at cruise speed on all roads, including ones I know it should track straight on.
I, too, found the comment about cars being designed to track right puzzling. After a proper alignment, my cars have always tracked straight. Not being mean, but I don't think I can subscribe to that theory.
No, the tires do not all match. 3 of them are good Pirellis, and the 4th is a cheap Tiger Paw, which is on the FL of the car. I am planning to rotate the tires this weekend, putting the Tiger Paw on the rear to see how it affects the steering. Damn Tiger Paw, POS. But it's what I could afford at the time. Maybe that tire will have a run-in with a BIG nail soon, or maybe a surprise midnight slashing.
I rotated the tires this weekend, and took it out for a spin. Definitely a lot less pull to the right. From the pull there was, I believe that to be due to the grade of the road. I appreciate everyone's input.
