help with my ej1 foglight diagnosis..
Old Nov 7, 2011 | 07:51 AM
MGBej1503's Avatar
Default help with my ej1 foglight diagnosis..
Ok so YES I SEARCHED. My issues: hooked em up last night everything worked perfect till I hit the freeway dips/drops in the road im assuming an they will not turn on. SWITCH STILL LIGHTS UP and relay still clicks when turned on. The wires to the cabin are still im tact. Any suggestions on what I should check out first. I will check sell connections again. Thank u for any input.
Old Nov 7, 2011 | 08:12 AM
grumblemarc's Avatar
The Grumpiest
Default Re: help with my ej1 foglight diagnosis..
Bulbs blown?
Old Nov 7, 2011 | 08:46 AM
MGBej1503's Avatar
They are brand new weren't even running for an hour
Old Nov 7, 2011 | 08:47 AM
MGBej1503's Avatar
So I sure hope not. I looked an all connections look fine. But if it was a connection wouldn't the switch not work?
Old Nov 7, 2011 | 08:49 AM
The Grumpiest
Does not the switch have it's own power? Just guessing because I don't know if you have OEM fogs or Ebay specials.
Old Nov 7, 2011 | 09:45 AM
si-ej1's Avatar
i had that same problem check ur ground on the left fog light make sure it gets good ground
Old Nov 7, 2011 | 09:57 AM
Wrona's Avatar
last time that happened was my relay my ebay foglights relay cost 30 dollars from napa where the foglights cost only 50...
Old Nov 7, 2011 | 10:07 AM
MGBej1503's Avatar
Yes they're the ebay ones but was hoping pick up a diff harness an possibly switch. I will check groundsi
Old Nov 8, 2011 | 11:41 AM
LoLoCivic's Avatar
Ground fosho!
Old Nov 8, 2011 | 11:42 AM
speedooo's Avatar
Sounds like a ground issue.
vtecdc4
Feb 23, 2012 06:24 AM
senorkree
20
Apr 5, 2010 11:01 PM
SouthSider13
Jan 15, 2010 07:10 PM
lilo_goki
Lighting
Oct 29, 2007 12:10 PM
3.point.2
Jul 20, 2006 06:12 AM
