b16 idle surge/wont rev after turbo install
Old Nov 5, 2011 | 03:46 PM
96f22b2's Avatar
Default b16 idle surge/wont rev after turbo install
Title says it all. At idle its always surging, and running super rich (wideband came un wired so i wasnt sure what the exact AFR was) but bblack smoke was coming from the downpipe. the only thing I can think of is the PCV valve is not installed. the valve/sensor itself is in the intake manifold but the vacume line broke off of it exposing the spring and screw looking thing. I have fuel pressure 45psi, and spark obviously, the minuet i touch the gas it revs up and dies. im running 480cc injectors, and im on a basemap so its not the injectors.. after about 45-50 hours total im exhausted and tired of messing with the freaking car. Any help would be great.
Thanks,
Curtis
youtube link to idle http://www.youtube.com/watch?v=H3bh0...el_video_title
you can see when I rev it, it revs then dies.
Old Nov 5, 2011 | 03:52 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 idle surge/wont rev after turbo install
First thing that comes to mind is crappy basemap. But you definitely need to fix the mechanical issues first.
Old Nov 5, 2011 | 03:54 PM
96f22b2's Avatar
Its a crappy off the shalf basemap from "some guy" i bought for $15. I wasnt planning on using it at all other then to get to the dyno. I may swap to the stock injectors and map and see how things go.
Old Nov 6, 2011 | 12:04 PM
96f22b2's Avatar
Fixed! forgot too tune in the hondata 4bar map sensor.
JoelAndrew
Oct 5, 2011 10:07 AM
chocolatesk8er10
Jan 20, 2009 11:23 PM
94HondaEJ
Jul 24, 2006 11:05 AM
VTcivicHB
21
Oct 31, 2005 08:01 PM
twkdCD595
Aug 21, 2004 02:32 PM
