Just installed Alarm with Remote Start, Now engine idles rough
Old Oct 6, 2002 | 04:28 PM
4DoorLS's Avatar
Default Just installed Alarm with Remote Start, Now engine idles rough
Installed the clifford RS2. My engine now idles roughly bouncing between 1200-1700 Rpms. Any suggestions for this? I dont' want to take it back to the shop because it was an under the table deal.
Old Oct 6, 2002 | 04:31 PM
Fuuma0083's Avatar
Default Re: Just installed Alarm with Remote Start, Now engine idles rough (4DoorLS)
Just wonder did you reset the ECU?
Old Oct 6, 2002 | 04:38 PM
piatl7il77's Avatar
ttt
Old Oct 6, 2002 | 04:54 PM
4doorB18Bcivic's Avatar
Default Re: Just installed Alarm with Remote Start, Now engine idles rough (Fuuma0083)
How would u reset a ecu??
Dont flame me just a simple question!
Old Oct 6, 2002 | 05:04 PM
4DoorLS's Avatar
Yes, reset ecu, it made it idle a little lower, before it was pushing 2K
(Reset ECU = unplug ground from battery(easiest). (or find the fuse and unplug it, smart way)
[Modified by 4DoorLS, 2:06 AM 10/7/2002]
Old Oct 6, 2002 | 05:14 PM
Fuuma0083's Avatar
Just taking off the ground isn't going to reset your ECU. You have to pull out the the two upper left fuses in your fuse box. 15 and 75. And leave it off for about 30 mins.
Old Oct 6, 2002 | 05:16 PM
Fuuma0083's Avatar
Here is a site from Team-Integra.Net on how to adjust your idle speed.
Thanks to StyleTEG
http://www.team-integra.net/sections...?ArticleID=195
Old Oct 6, 2002 | 06:06 PM
4DoorLS's Avatar
thanks for the info, I'll try it tommorow and see what happens.
Old Oct 6, 2002 | 09:38 PM
SIK IN DA HED's Avatar
New User
they probably messed with your idle. me and a lot of my boys got remote start and we never had that problem. my cousin installs em and tampering with the idle is not part of the installation process. just easy installation to the ignition.
Old Oct 7, 2002 | 03:03 PM
4DoorLS's Avatar
after the ecu reset, it still bounces a little during warm up time. After couple mins, it sits at 900 rpm; slightly higher than specs. But when I am driving, right after I let off the gas to put it in neutral, the rpms drop, but bounce a couple times before setting at 900 rpm.
Does this seem to be a remote start problem or air flow problem, Because I had just recharged my filter the day before the install. I am positive it did not do this right after the air filter recharge.
philibuster
Sep 9, 2003 11:17 PM
Grimm
Sep 23, 2002 01:10 PM
-Whitey-
Sep 18, 2002 06:03 PM
00fbp
Aug 16, 2001 08:18 PM
