code 22 vtec pressure switch
Old Nov 4, 2011 | 02:16 PM
EF-ingB16's Avatar
Icon2 code 22 vtec pressure switch
so i rebuild my motor and i put everything back together and now I am geting a check engine light and code 22. when the light is on the vtec doesnt work but the light doesnt alway come on right away and when it doesnt the vtec works fine. is the pressure switch bad or is a wiring issue. before i tore the motor apart everything worked fine.
Old Nov 6, 2011 | 09:14 AM
ktsciv93's Avatar
Default Re: code 22 vtec pressure switch
could be wiring or the pressure switch itself, or oil pressure... i'd check the wiring first, as it is quite a bit cheaper then a new switch. but it could be either really..
Old Nov 6, 2011 | 10:04 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
UDUBdriver
Engine Management and Tuning
Sep 4, 2011 07:04 AM
fw190bvi
Jul 23, 2009 03:17 PM
Blake97GSR
Nov 7, 2003 06:01 AM
