94 Honda Civic Ex Starting Problems
Old Nov 4, 2011 | 08:20 AM
spunk651's Avatar
Default 94 Honda Civic Ex Starting Problems
I got a 94 Honda Civic Ex and it seems to have trouble starting, I have changed the distributor, alternator, fuel pump, fuel relay, fuel filter, and it's still not starting? the problem seems to be in the fuel system, no pressure, could it be the fuel pressure regulator? when i go to relieve the fuel pressure from the filter, nothing comes out. So i am clueless to what it is. Or is the fuel lines clogged? or could it be the fuel injectors? I know that if even one of the injectors is clogged it could still be able to start right? Well, I am stumped, any help and suggestions will be appreciated.
Old Nov 4, 2011 | 08:27 AM
Dioxine's Avatar
Default Re: 94 Honda Civic Ex Starting Problems
Does your fuel pump turn on? You might have bad wiring to it.
Kumpy
Oct 23, 2015 02:35 PM
autotegra
Honda Civic (2001 - 2005)
Jan 28, 2015 07:38 PM
caspersrevenge1
Sep 6, 2013 05:02 PM
tru3drag0n
Jul 5, 2010 01:52 AM
iNetForce
Nov 13, 2005 08:27 PM
