Changing a fuel filter
Old Nov 4, 2011 | 07:35 AM
motegicivic's Avatar
Default Changing a fuel filter
96 civic EX
I know you need to pull a fuse ........which one, and is under dash or hood?
After you pull it let it run until dies right?
Also, to get the filter off the bracket, some say you need a 10mm deep socket, is a deep need or a reg socket and an extension will work?
Old Nov 4, 2011 | 07:55 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Changing a fuel filter
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-96-00-honda-civic-tune-up-fuel-filter-2872418/
Old Nov 4, 2011 | 08:24 AM
thenext's Avatar
20% cooler
A socket with an extension will work. That filter can be a REAL knuckle buster without one.
Old Nov 4, 2011 | 08:26 AM
jdmcx's Avatar
i have never pulled a fuse I do it the same way in the link.
Old Nov 4, 2011 | 08:33 AM
apexi_rsx's Avatar
as posted above there is no need to pull a fuse just make sure the key is off or not in the ignition.
Old Nov 4, 2011 | 09:11 AM
The reason to pull the fuse is to flush the system of fuel, when you crank it the car runs until the gas cuts off, so no spilling of gas when you remove the filter.
Old Nov 4, 2011 | 09:13 AM
grumblemarc's Avatar
The Grumpiest
Flush? I thought it was just to relieve pressure. There is no need. Get a shop rag.
Old Nov 4, 2011 | 09:16 AM
thenext's Avatar
20% cooler
Doesn't hurt to take the gas cap off and it's a little less messy if you do it on an low tank.
Old Nov 4, 2011 | 09:35 AM
The Grumpiest
All of this is in the link provided in post #2. What's the discussion for? Follow the damn directions. It even has pictures.
Old Nov 4, 2011 | 09:55 AM
jdmcx's Avatar
no need to "flush" system just follow the info in the link it has more info than the autozone manual.
Old Nov 4, 2011 | 11:02 AM
Int3graz's Avatar
yah I wasted like 87 cents of fuel that dumped out of my old filter..... not a big deal
Old Nov 4, 2011 | 11:16 AM
turbodcxbro's Avatar
WTH does taking the gas cap off have to do with changin the filter?? Messy with a low tank??? what are you changing the filter on dude?
Old Nov 4, 2011 | 12:51 PM
Int3graz's Avatar
I think it lowers the fuel pressure so it doesn't drip out as much when you take the line off the filter.... but this thread should be closed anyways i'm done!
Old Nov 4, 2011 | 12:54 PM
The Grumpiest
It's not your thread. Follow the instructions, look at the pretty pictures and you'll get your filter changed with the minimum of hassle.
Old Nov 4, 2011 | 01:39 PM
Kista20's Avatar
If you take the cap off it relieves all the pressure that is built up in the tank. I've never removed the fuse but you could try that and then start the car for extra measure... however at the very least I would at least remove the cap.
You will also want tube nut wrenches and you'll want to break loose the fuel lines before you start messing with the bracket. I don't remember if it's the top or bottom bolt but it will be a pain no matter what, I should know because it's always that same one. If the filter comes with two copper washers you wil need them for the top bolt but toss the smaller one in the can as it's not needed for the bottom one.
Old Nov 4, 2011 | 04:20 PM
Correct you remove the cap to relieve pressure, I was just trying minimize gas spilling out, that is why I saw the tip about taking out the fuse and then running it till it stops.
Old Nov 4, 2011 | 04:23 PM
The Grumpiest
Just get a rag to catch the spillage. It's not going to blast out like a fire hose.
Old Nov 5, 2011 | 06:53 AM
The fuel cap has nothing to do with the line pressure in a fuel system! It will merely release built up tank pressure/vapors, which is what a properly working evap system does. Fuel line pressure is controlled by your FPR and it is maintained by the one-way check valve in your fuel pump. Removing your gas cap will do nothing to prevent fuel from coming out of the lines when you take the filter off.
If you truly want to do a filter change and not lose ANY fuel then yes, removing the fuel pump fuse and running the car til it shuts off will drain your lines almost completely. But truthfully your only going to lose a small amount of gas as long as you let the car sit awhile before you crack the filter lose, they only hold pressure for like an hour..
Old Nov 5, 2011 | 02:00 PM
Int3graz's Avatar
I know it's not my thread I'm saying this is a pointless one! Uhh yah that's what I did actually unlike the OP... and I put my 2 cent's in and gave him help even though I should of just said READ THE FAQ on how to change fuel filter!!!!!!!!!
Old Nov 6, 2011 | 08:59 AM
Not the point of the thread, there different ways to do things, I was merely asking which fuse it was, some people do not care if they make a mess, say changing a thermostat and not draining some coolant and letting go all over the trans to the ground etc.
Smash03
Mar 21, 2010 07:19 PM
TerribleOne
Mar 26, 2003 05:33 PM
Krayzielix
Feb 6, 2003 09:24 PM
HiRevn
May 18, 2002 06:50 AM
boost killz
Jul 31, 2001 11:32 AM
