My steering column is not straight? Help
Old Nov 3, 2011 | 11:19 PM
Raiderz8418's Avatar
Default My steering column is not straight? Help
1996 Civic Coupe EX Y8
Im not sure if its called the steering column since the car drives perfect but its the plastic piece that has the turn signals and wipers? Its skewed to the right so when i put the top cover it wont close due to the turn signal stick hitting it.
As you can see its skewed to the right, how can I turn this straight?
Old Nov 3, 2011 | 11:30 PM
rickyracer's Avatar
Default Re: My steering column is not straight? Help
that's because the car was stolen before...i got my em1 like that and it was because the ignition switch is on the right and that's were it was pried.
Old Nov 4, 2011 | 05:08 AM
Is there any way to shift that straight?
Old Nov 4, 2011 | 05:49 AM
thenext's Avatar
20% cooler
It's splined on there. I doubt it is going to be something you are going to be able to repair. You can take your steering wheel off and replace it with a new one.
Old Nov 4, 2011 | 06:07 AM
What exactly do you mean by splined? What do I replace for a new one, the whole steering column? or just that piece? If so what is it called?
Old Nov 4, 2011 | 06:11 AM
thenext's Avatar
20% cooler
It's called a multi function switch. Splined means that it is held in place by splines. Take a look at a shop manual and it will tell you how to get the steering wheel off. Probably want to disable your airbags while in this area.
Old Nov 4, 2011 | 06:20 AM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Nov 4, 2011 | 06:41 AM
Okay but replacing the steering wheel wont do anything, to my understanding whats crooked is the metal piece in which the wipers and turn signal attach to.
The black piece that has the wipers and turn signal can be put straight by removing the two screws from the metal piece thats crooked. Its that metal piece that needs to be replaced?
Old Nov 4, 2011 | 06:57 AM
thenext's Avatar
20% cooler
I am not telling you to replace the steering wheel. I am telling you that you have to take the steering wheel off to replace the multifunction switch, which is that "black thing."
Old Nov 4, 2011 | 07:09 AM
Okay sorry, but like I said the black thing with the wipers and turn signal is not whats bended but, instead it's the metal piece that's it's screwed to. The black thing can be pot on straight by removing the screws. Therefore it's that metal piece that is the problem, wouldn't a steering column bring that metal piece so I can just attach the black thing and steering wheel?
Old Nov 5, 2011 | 01:30 AM
rickyracer's Avatar
you will need to replace the whole assembly. go to a junkyard and find a steering column that looks straight.it has like 6 screws to remove the whole thing. takes about 20 minutes...
SHG_Claudio
15
Jun 21, 2009 08:19 PM
Demonis
Honda Civic (2006 - 2015)
Aug 16, 2007 08:12 AM
n00b
Jun 7, 2005 04:55 PM
Teggys1ClnDA
Jan 21, 2005 02:44 PM
