ATTN - techs. Wheel Wobble
Old Nov 3, 2011 | 07:40 PM
PaulMc's Avatar
Painfully Stupid
Default ATTN - techs. Wheel Wobble
Just picked up a '98 Civic EX coupe. The rear passenger side wheel has a wobble that is apparently noticable while the car is moving, but I don't feel it while driving. I picked the car up off a buddy of mine who knows absolutely nothing about cars or fixing them, and he said that his mechanic told him that he needed a tirod . I didn't remember that tirods only apply to the front of the vehicle until after i bought the car.
Anybody know what could be going on here? It's not the hubcap because their isn't one on there, it's clearly the wheel. I jacked the car up and the wheel doesn't wobble around and everything feels tight, but when I'm driving people tell me the wheel is all over the place and looks like it's going to fall off.
I searched but I couldn't find anything revelent to this, any help in here before I spend money I don't have at a mechanic would be apreciated.
Old Nov 3, 2011 | 08:19 PM
98civdx's Avatar
Master Detailer
Default Re: ATTN - techs. Wheel Wobble
I would suspect the wheel bearing.
Or, a bent wheel.
Old Nov 3, 2011 | 08:23 PM
Kohen's Avatar
Or, a bent wheel.
x2
Old Nov 3, 2011 | 08:34 PM
speedooo's Avatar
Have you had somebody else drive it so you could see it wobble? There's only three things that could make the wheel wobble or atleast appear to wobble:
1) bent wheel
2) loose lug nuts
3) bad wheel bearing
Don't take it to a mechanic. Just buy a 96-00 ex rear trailing arm off of craigslist for $30 and swap it.
Old Nov 3, 2011 | 08:54 PM
j.dmcar's Avatar
you should just check your wheel.
-wheel weights are off
-bad tires?
-messed up axles?
.. etc
this sounds very unssafe..
Old Nov 3, 2011 | 09:09 PM
98civdx's Avatar
Master Detailer
^^^ Don't have axles in rear,buddy.
Old Nov 3, 2011 | 10:11 PM
LoLoCivic's Avatar
sounds like a bent rim since u said yourself it doesnt feel loose or anything
Old Nov 5, 2011 | 09:26 AM
PaulMc's Avatar
Painfully Stupid
Well none of this sounds very expensive. I had a wheel bearing go bad once on the front but the wheel would wobble when I jacked it up, this time the wheel doesn't wobble when jacked up as if there isn't anything wrong. I'll just try swapping it with another wheel and seeing if it could just be a bent wheel.
Old Nov 5, 2011 | 09:58 AM
98civdx's Avatar
Master Detailer
Rear bearings can be kind of spendy becuase you have to replace the whole hub.
On the bright side, they aren't that hard to change.
Old Nov 5, 2011 | 11:20 AM
frankenghia's Avatar
just jack it up and look at it for yourself before spending any money. If you think its a wheel, switch it with one of the other three. If it goes away. Viola!!! Its your wheel. If it doesn't go away then you need to replace the hub assembly.
Old Nov 5, 2011 | 12:42 PM
hyperblu's Avatar
Jack it up and spin the wheel. You will definately hear it if it's a bearing.
DEEABLO
Jun 10, 2009 08:02 PM
Markov
Sep 23, 2006 12:31 PM
