D16Y8 bogging down
I have a 2000 civic ex D16y8. It bogs down when the engine gets warm and i'm in gear. There is no power gain what so ever, I basically just coast to a stop. If you push in the clutch the motor will rev fine. There is a CEL but it's just because of the test pipe. Simulator is on the way. I just changed the plugs wires cap and rotor about a month ago. Any ideas???? Thanks
I already have a test pipe in and have the spark plug non fouler trick installed but it doesn't work. I have a simulator on order and am just waiting on it to get here. My car has been running in limp mode for about a year now and has just started acting up. Can it really be the o2. It has ran fine without a simulator for a year now?????
Secondary just makes sure the cat is working properly, primary (in front of cat) is this one that does most of the work the o2 does. So in short answer, if it is the o2 then the primary is the one you'll need.
What you are saying is that you don't really know what CEL codes are currently thrown. Jump the service connector to pull the codes, and then post them.
Also check the mechanical timing.
Running in Limp Mode for that long can't be good for the motor
oO
Could it have possibly also fouled up the primary O2 since limp mode retards the ignition timing?
(or are my facts all fracked up here? ^^; )
oO
PhoebeusFenix
Jan 17, 2005 06:20 PM
comptechgsr2000
Apr 26, 2002 09:02 AM
