Possible to use a BOV as a wastegate??
Old Nov 3, 2011 | 02:44 PM
champLSinteg's Avatar
Default Possible to use a BOV as a wastegate??
My buddy is going to be using the kraft works supercharger. We need a way to control boost and maybe be able to use boost-by-gear. I could just use an older 38mm Tial wastegate on the piping but its heavy and not nice on the eyes. Now I am wondering if I could make a bov work as a wastegate. Is this possible?
Old Nov 3, 2011 | 03:08 PM
LightningTeg's Avatar
Community Builder
Default Re: Possible to use a BOV as a wastegate??
No. A BOV works under the opposite effect. To keep the valve closed until vacuum.
Old Nov 3, 2011 | 03:14 PM
Would the bov stay closed under boost if there was no boost line fed to it?
Old Nov 3, 2011 | 03:47 PM
Ovrbst_T66's Avatar
Depending on spring pressure in bov it should
Old Nov 3, 2011 | 04:38 PM
viper_boy403's Avatar
It could work as a pop-off valve if adjusted properly. My friend's RX7 did that @ 15psi to a Greddy BOV that was nearly all the way loosened
Greddy makes an adjustable pop-off valve
http://www.greddy.com/products/turbo...:Relief+Valve/
Old Nov 3, 2011 | 04:55 PM
TheShodan's Avatar
Moderator
I've seen many use a wastegate as a BOV because of the high amount of pressures that the Drag car sees (over 60psi + of boost pressure). but definately not the other way around. it doesn't work well that way. And even then, on a turbocharger, not a self contained supercharger
Old Nov 3, 2011 | 09:05 PM
SovXietday's Avatar
I'm pretty sure there are bypass valves designed for this purpose.
Cimburke23
Mar 29, 2006 02:20 PM
Dunc
Jan 17, 2005 05:52 AM
ThePro
Nov 10, 2004 09:36 AM
GSRswapandslow.
Mar 31, 2004 09:05 AM
safe driver
May 1, 2002 02:44 PM
