Battery dont hold charge
Old Nov 3, 2011 | 02:41 PM
Rickdogg's Avatar
Default Battery dont hold charge
Ever since I put my new clutch in my battery hasn't been holding its charge I have a new altinator batterys still good dont know w hat it could be if I dont drive my car for a day battery dies but if I drive it everyday then its fine? any help pls
Old Nov 3, 2011 | 02:47 PM
JDM-Punk's Avatar
Default Re: Battery dont hold charge
not 100% by all means, but it could have a cell going out on it (i know at my job some batteries we get show good when on a load tester, but will die soon after due to a cell being bad)... try getting the cells tested or borrow a friends battery to see if that one would hold a charge, that way you could def be able to tell if its battery or car related
Old Nov 3, 2011 | 06:12 PM
zrickety's Avatar
How old is the battery? If you have door seat belts, they can drain the battery when the door is not shut all the way. Cold weather is usually the last straw for a tired battery.
Old Nov 3, 2011 | 07:02 PM
KINGVEM^^ED6's Avatar
Bad grounds posibly? Go get it tested at vatozone
Old Nov 4, 2011 | 02:04 PM
sstupid's Avatar
10 Year Member
It's simply a bad battery, or you have a drain. Disconnect the battery cable one night, hook it back up the next morning, and see if the car starts. If it starts, you have a drain (PITA). If it doesn't start, you need a new battery (EASY).
Old Nov 23, 2011 | 03:57 PM
Rickdogg's Avatar
What if my door light keeps flashing while im driving could that drain my battery when i turn it off
Old Nov 23, 2011 | 04:10 PM
24TEN's Avatar
PHANTOM MENACE
All electrical runs off of the alternator while driving.
patrickstar
Audio / Security / Video
Jul 15, 2009 04:38 PM
crxaddikt
Honda Civic (2006 - 2015)
Apr 8, 2009 06:25 AM
Turbo_Mike
Apr 30, 2006 06:25 AM
Project X
Feb 24, 2004 05:44 AM
EGh22aEG
Apr 19, 2002 12:05 PM
