OBD1 to OBD2A swap ????
Old Nov 3, 2011 | 01:56 PM
95Sol99civic's Avatar
Default OBD1 to OBD2A swap ????
I have a 97 civic hatch was auto swapped to 5 spd. Engine is a Z6 with a P28 ecu. There is no engine light but the idle is up n down. I also have a 1998 Y8 intake manifold. Theres no FITV. So am I gonna have to get the ecu flashed to fix that? Any ideas would be great thanx.
Old Nov 4, 2011 | 05:14 AM
Default Re: OBD1 to OBD2A swap ????
Hello? Bump Bump
Old Nov 4, 2011 | 07:58 AM
HondaPartsHero's Avatar
Technical Hero
No fitv or no IACV?
Old Nov 4, 2011 | 09:35 AM
I have a IACV but its clean n works fine no engine light.
Old Nov 4, 2011 | 04:51 PM
habib's Avatar
Does it do it constantly even after it is fully warmed up?
Old Nov 4, 2011 | 05:33 PM
apexi_rsx's Avatar
when the FITV is blocked off u will not have any warm start it should only rev to 1000rpms the whole time even when warm. it sucks not having it in cold climates but ive ran mine this way for some time now with no problems. no u do not need a reflash it will not fix this at all. if its bouncing u may wanna look into how they plugged the FITV and make sure they did the 3wire to 2 wire IACV correctly. look up the 3 wire to 2 wire IACV conversion and double check. if it constantly bounces when cold and warm u may have a vacuum leak.
Old Nov 4, 2011 | 08:27 PM
98civdx's Avatar
Master Detailer
pop the intake tube off.
While runing, cover the TB, if it stays running you have a vacum leak. Any hissing sounds?
Old Nov 5, 2011 | 04:43 AM
Well its a 98 Y8 intake. they didnt have FITV its controled by the computer. I have the wiring right cause if not I would be getting an engine light right? I take my intake arm off n stick my finger in the hole, no change. This has really got alot of poeple frustrated lol.
Old Nov 5, 2011 | 04:44 AM
yes very annoying.
Old Nov 5, 2011 | 04:48 AM
When I had a TB with a FITV it did the same. Im still gonna try and see if theres an intake or vacuum leak. I just wanna check everything.
Old Nov 5, 2011 | 06:35 AM
apexi_rsx's Avatar
put ur whole hand over the throttle body while its idling. does the car stay running or stumble and shut off?
Old Nov 5, 2011 | 07:59 AM
98civdx's Avatar
Master Detailer
I didn't say stick your finger in, cover it. both hands, hell, put a peice of wood of something over it.
Old Nov 5, 2011 | 02:52 PM
Ok ok. lmfao. And if it stumbs n dies? Cause I really dont think there any leaks. Should know in a few.
Old Nov 5, 2011 | 03:13 PM
98civdx's Avatar
Master Detailer
If it stumbles, and dies, thats a good thing. That means you have no vacume leak.
A leak can cuase what you described.
Old Nov 5, 2011 | 04:14 PM
Ok then what is the problem after that tho? lol
Old Nov 5, 2011 | 04:34 PM
98civdx's Avatar
Master Detailer
Don't know.
it's an easy test that will eliminate a vacuum
Old Nov 5, 2011 | 04:49 PM
98civdx's Avatar
Master Detailer
Also check the coolant. Air in the cooling system will can this
Old Nov 7, 2011 | 06:57 AM
Ok found out that its something to do with the intake gasket. So which gasket should I use the 98 EX or 95 Si del sol? I put the 95 del sol one on the first time so I guess Im gonna try the 98 EX. The funny thing is the 95 gasket is $12.99 the EX is 6.99. WTF? I hope a good up date here soon
Old Nov 8, 2011 | 07:57 AM
Ok heres the problem The Y8 manifold has holes above the injectors. It dont matter which gasket I use the holes are not covered. So no what guys? Seal it up? With what?
Old Nov 8, 2011 | 10:34 AM
Well JB weld is my friend. Thanx for the help fellas. Now IA is looking promising.
ScottyBobby
19
Jan 4, 2011 06:02 PM
LiL JoN
Oct 27, 2010 01:34 AM
important
Nov 5, 2007 05:34 AM
GiMpInThaCiv
Jun 1, 2006 07:59 AM
JDM96SpecCTR
Jun 24, 2005 03:14 PM
