b18b1 into del sol wont start
Old Nov 2, 2011 | 11:22 AM
Brockasaurus's Avatar
Default b18b1 into del sol wont start
So i put a ls in my del sol and i saw the motor run right before i put it in my car it was in my good buddys car. the timing is dead on and has never been messed with.. i couldnt figure out why my fuel pump wouldnt prime but i figured out it was the thermostat ground so i fixed that now my check engine comes on goes off like it should but it just keeps cranking.. i just put a new cap rotor and wires on it... i accidentily got water down the plug holes but i got that all out with a vacuum and rags but could that of ****ed the plugs up and cause it not to start i dont have a deep enough 5/8ths at the moment to pull them to see if i am getting spark but im just wondering if any one else has some input on what it could be.
Old Nov 2, 2011 | 12:35 PM
Former User's Avatar
Default Re: b18b1 into del sol wont start
Compression test the cylinders.
Old Nov 2, 2011 | 06:36 PM
I don't think its that though bc I just drove the car with this motor before I pulled it and it ran strong like real strong no missing or nothing and only had 68,000 miles and the oil looked amazing
Old Nov 2, 2011 | 06:41 PM
EJ1 LS guy's Avatar
If your getting fuel,have compression, then spark is the only thing left i can think of. change your spark plugs and check the dizzy(make sure everythings plugged/tightened inside).
splashy
Sep 10, 2017 08:48 AM
Mothgoul
Oct 3, 2011 05:08 AM
hamilton_sol
Mar 18, 2007 02:40 PM
4ghatch
Mar 10, 2007 10:08 PM
gilligan354
Mar 14, 2006 01:34 PM
