Suspension & Brakes Theory, alignment, spring rates....
Aftermarket EG RLCAs with EK bushings
Old Nov 2, 2011 | 09:52 AM
Mr. Winky's Avatar
Default Aftermarket EG RLCAs with EK bushings
Here is the scenario:
Current setup is as follows:
-94 Civic dx hatchback
-Using 96-00 Tein Mono-Flex Coilovers.
-Oem 92-95 Eg Rear lcas with 96-00 Ek center bushing to accommodate the slightly narrower Ek suspension forks.
I am currently running this setup on my car with absolutely no problems whatsoever, however I would like to run aftermarket rear lcas, but most Eg aftermarkets (ie. Function7, Skunk2, etc) do not have any options to change out the center bushing to a narrower Ek size. I reqally want to get the F7s again, but I do not want to grind down any aftermarket bushings on brand new control arms.
I really do not want any blox, bwr, ebay lcas..
so with all of that being said. Does anyone have any realistic suggestions? Please post up what you have done or any possible solutions. Im sure other ppl have done this.
Old Nov 2, 2011 | 10:46 AM
phunhaus's Avatar
Default Re: Aftermarket EG RLCAs with EK bushings
Call Function 7. Ask for EK bushings.
/thread
Old Nov 2, 2011 | 11:52 AM
STOCK_SOHC_DX's Avatar
/thread
This kinda, I have called F7 in the past about it and they have to actually machine down the arm a little bit. If they do it and not some backyard mechanic you also retain the warranty.
Old Jan 12, 2012 | 01:06 PM
Mr. Winky's Avatar
Do you have any idea how much this would be be? I don't mind spending the money for f7, but I really want to stay somewhat reasonable on budget
Anyone else have any Lca suggestions or Riyadh ideas?
Old Jan 12, 2012 | 01:24 PM
grumblemarc's Avatar
The Grumpiest
What's wrong with using washers? Or am I misunderstanding the "scenario"?
Old Jan 12, 2012 | 03:24 PM
98civdx's Avatar
Master Detailer
You have it backwards buddy.
EG onto EK you need washers as the forks are wider.
EK onto EG you need to trim down the bushings as the forks are narrower.
Old Jan 12, 2012 | 03:41 PM
Mr. Winky's Avatar
Correct.
Old Jan 12, 2012 | 03:54 PM
The Grumpiest
Gotcha. I had it pictured backwards in my head.
Old Oct 29, 2013 | 03:13 PM
94EGCoopey's Avatar
Necro bump.
Called F7, no response for days.
Any other options?
Old Oct 29, 2013 | 03:59 PM
Andy@AMR's Avatar
We are a Function 7 Distributor. I can build a set of Function 7 EG arms with EK shock bushings no problem.
Old Oct 29, 2013 | 05:42 PM
94EGCoopey's Avatar
Awesomesauce. Sending you a PM.
Old Oct 29, 2013 | 05:54 PM
Andy@AMR's Avatar
No problem. That's what we are here for. We will get you taken care of. Make sure to LIKE our FB page for coming through!
724chris
Feb 5, 2010 05:09 PM
jbecke2
Mar 19, 2008 10:38 AM
1 jonesie
May 20, 2007 05:08 PM
.::miLan
Suspension & Brakes
Nov 15, 2005 05:31 PM
KillBot
Mar 12, 2005 10:56 AM
