so confused.. ek suspension on eg help
ok so i wanna put some ek struts on my eg..
i understand that the front all i have to do is use the ek forks(correct me if wrong)
and im not so sure about the back.. some forms say i gotta grind the bushing on my eg lcs and some kid that has the suspension is telling me you need no modification.. tell me how it works
Re: so confused.. ek suspension on eg help
Im not 100% but i think the fronts will work.
For the rears, EG lca's are wider than EK lcas, soyou would have to use EK LCA's in the rear in order for it to work.
If im wrong someone will correct me...
i read the ek lcas are also longer. i read they were wider also thats w u have to grind the bushings down but idk
my brother put tein type flex from an eg on his EK and had no problems.... yes the back LCAs are diffrent but should work.... as far as i know he didn't have to do anything to make them fit.. if anything the backs were tight..... i will call him and ask....
EG bushings are wider, so yes you have to grind them down. The front two need no modification. This faq should help:
http://www.hondashowoff.com/forums/s...ad.php?p=70063
yes the front will fit but the rear mounting to the LCAs are diff. eg to ek you have to use spacers to make them work but the ek to eg might be to tight... and i dont have any pics sorry... this is what my brother told me..... i hope this helps out...
KillBot
03-12-2005 10:56 AM
