Honda S2000 Honda S2000
LOUD NOISE ON TOP END
Old Nov 2, 2011 | 08:46 AM
lsvtechatch92's Avatar
Default LOUD NOISE ON TOP END
A buddy of mine is having a problem with his s2k.. .it is stock has about 90 k on it and it sounds like there is gerbil in the front of the valvecover banging around with a wrench! He just replaced the timing chain tensioner and it is still doing it! He claims valves were adjusted as well but im going to redo that.. but it sounds wayy to loud to be a valve adjustment and it sounds likes its more in the front.
Old Nov 2, 2011 | 01:59 PM
MONSTERZC's Avatar
Default Re: LOUD NOISE ON TOP END
I would tell him to stop driving it till it gets looked at. I would also have him explain every step he did to you, so you have the proper infomation. (also ask if he keeps up with the oil changes) Was the noise the same as before did it get worse. I would also check the timing chain gaurd. Without a video of the sound or pic it hard to say for sure.
Old Nov 3, 2011 | 07:45 PM
Rtzx9r's Avatar
GDD 1%
what rpm does it start at, and is it only when in vtec? Did the noise start all of a sudden, or gradually over several months?
Old Nov 4, 2011 | 06:05 PM
it happens as soon as you start it. It is pretty loud and it is on the top end.. it is not a bearing... Im thinking timing chain parts related... sounds like a damn diesel truck
Old Nov 4, 2011 | 07:00 PM
apwhat's Avatar
did he replace the timing chain tensioner himself, my guess is he did it wrong. I would take it apart, inspect, and try again. Make sure to trq the bolts down per spec.
Old Nov 4, 2011 | 10:07 PM
he did have it changed by whom i dont know. im just gonna have to pull it apart and look at all.
Old Nov 4, 2011 | 10:09 PM
boooosted's Avatar
Maybe a sticky lifter also?
Old Nov 4, 2011 | 11:47 PM
HdeucedeuceA's Avatar
Old Nov 5, 2011 | 04:44 PM
postman's Avatar
cracked or broke retainer? what year is this? scored cam journal?
Old Nov 6, 2011 | 12:29 AM
Didn't think about the retainers. Pull the valve cover and inspect.
Old Nov 6, 2011 | 12:39 AM
Dioxine's Avatar
What?
Old Nov 9, 2011 | 01:40 PM
importknight's Avatar
O thats just VTECCCC!!
Old Nov 14, 2011 | 06:03 PM
AJR Jay's Avatar
Hey there,
Does the sound follow the engine rotation? Let me know, I can get this diagnosed for you.
Thanks.
Jason @ AJR
Old Nov 18, 2011 | 03:15 PM
peklngduckk's Avatar
lol importknight, I had to scroll up to see if you were the TC, I was about to say...
HeLLa iLL2ndGen
Aug 12, 2010 01:22 PM
EK45VTi
15
May 2, 2007 10:16 PM
ek4h
Apr 5, 2007 05:19 PM
vicd_teg
Mar 22, 2007 09:24 PM
Capsule Kid
Jun 13, 2005 01:14 AM
