95 Civic ex coupe "WHAT IS THIS?"
Old Nov 1, 2011 | 10:44 AM
95civic_ej's Avatar
Default 95 Civic ex coupe "WHAT IS THIS?"
I need help to identify this area? Can anyone please tell me what this is? that green plastic broken part.
D16z6 1995 Civic ex coupe
Thanks.
Old Nov 1, 2011 | 10:55 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: 95 Civic ex coupe "WHAT IS THIS?"
pretty sure it's the vtec pressure switch, you will need to replace yours
Old Nov 1, 2011 | 10:56 AM
Former User's Avatar
I believe it's the 2P connector for the VTEC oil pressure switch.
Old Nov 1, 2011 | 10:57 AM
grumblemarc's Avatar
The Grumpiest
It's all of the above. And it's broken.
Old Nov 1, 2011 | 12:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
Pressure switch: 37250-PR3-003 $50
O-ring 13x1.5: 91319-PR3-003 $1.75
You could always try to find a used switch, but they are usually sold with the whole solenoid.
You could also cheat and wire your pressure switch to your VTEC solenoid as well, but you won't pass inspection with that broken sensor. It will however allow the engine to run like normal and keep the check engine light off. This is what we do for JDM motors (no pressure switch) running off US ECUs.
Old Nov 1, 2011 | 12:14 PM
delsolo95's Avatar
pretty sure you have a check engine light for that. once you replace the vtec pressure switch, reset the ecu
Old Nov 1, 2011 | 02:25 PM
95civic_ej's Avatar
Thanks all you you guys and it is broken but my check engine light is off. not on. thanks again.
Old Nov 1, 2011 | 02:27 PM
Does the CEL work?
Old Nov 1, 2011 | 02:29 PM
speedooo's Avatar
The CEL for vtec will only come on if you are running a VTEC enabled ecu and you surpass the rpm of engagement.
Old Nov 1, 2011 | 04:54 PM
95civic_ej's Avatar
Yeah your right, my whole car shut off when revving it. and the check engine light went on.
Old Nov 1, 2011 | 09:48 PM
LoLoCivic's Avatar
well thats easy to replace. just replace the switch that can be taken off from any vtec solonoid i believe.
Old Nov 2, 2011 | 01:09 AM
HondaPartsHero's Avatar
Technical Hero
^That's true
Old Nov 2, 2011 | 05:46 AM
trickshift's Avatar
its quite easy i believe there are two switches like that on the engine. one is vtec and i cant remeber off the top of my head what the other one is for but theyre the same and interchangeable to my knowledge
Old Nov 2, 2011 | 06:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
[sarcasm]Wow, that is soooo easy.[/sarcasm]
Old Nov 2, 2011 | 09:30 AM
95civic_ej's Avatar
well thanks guys i replaced it yesterday and now it working fine.
TravisCadello
Feb 9, 2009 10:39 AM
allmotorb18c14door
Mar 21, 2007 03:30 PM
