92 civic overheating??? please help!!
i reacently bought a swap fro my 92 civic, when i had a b16a it never overhated at all, now i have b18c1 built(ls crank, rods, B16 pistons) and it over heats over a few days? i have replaced everything, fan switch, radiator 22t water pump no leak from hoses, OEM thermostat. temp sensor on the head and radiator cap.
the car runs good, the problem its that it pushes the water to the resevor and then when sitting at a light it begins to overheat. i donot know how to approach the problem anymore, i begin to think that it might be because the car might be running lean? but i dont think that it would be that dramatic as to overheat the car... i dont know what the problem could be. please help!! i think that the car might have a block guard? but i am not sure as i was not the builder of the engine...
only when ideling... i have taken the car on roadtrips and it donsent overheat on highway, but as soon as im off the needle just rises..
It sounds like the fan. Check the fuse, it could be blown. If its not, check the obvious and make sure it plugged in. If it is and it still doesn`t work, than test it and see if its getting power. If it, and it`s not spinning, then the little fan motor is prob dead and you HAVE to get another. Anyone correct me if Im wrong.
He did say he replaced the fan switch.
When idleing, can you hear the fan come on, if not go check to make sure, eventhough new fan switch doesn't mean that is the problem.
I would def go the bleed route.
I have the same problem.
Another scenerio could be the headgasket going as well, might want to do a block test.
yes fan does work and i also have it wired to the AC fan so when i turn on the ac both fans come on, ive also bleeded the system like 10 times and nothing...
if the fan is wired to the ac then it will only come on when the ac does. the fans cycle at different intervals.the ac fan kicks on when pressure goes up in your system. If you have it hooked up this way your radiator fan will only come on when the pressure in your ac sytem goes up and not when your engine temp goes up. this seems to be your issue. either hook it back up stock or wire it separately to a toggle switch. hope this helps
Michael T Lelis
Jul 20, 2015 05:37 PM
CRXB5
11
May 23, 2011 03:11 PM
92civiclxny
Jul 22, 2010 05:14 AM
krisfnbs
76
Feb 23, 2010 12:06 AM
