99 si b16a2 fluttering rpms after warm-up HELP!
Yeah so, when I first start it up the car runs great...but once it warms up and i'm at idle..the rpms will flutter from about 900 to 1900...then back down to 900 then up to 1900..you get my drift. I've ordered a new TPS. I have no noticeable vacuum leaks, new plugs and wires. Lets say when I install the new TPS and it doesn't correct the problem, where should I turn??? I plan on cleaning out the throttle body and replacing my fuel filter...it's time. Let me know what you guys think. BTW I do have a bad o2 sensor.....?
What codes are thrown?
Have you bled the cooling system?
When the idle problem is happening, does covering the hole inside the throttle body leading to the IACV make the idle surging stop?
Well for the new TPS anyone need one...ha. Oh well good to have around j.i.c. Thanks
rcjustin
26
Feb 3, 2006 10:37 AM
turbo Si
Jun 10, 2003 07:52 AM
