Question about R LSD
Old Oct 6, 2002 | 02:53 PM
lube's Avatar
Default Question about R LSD
Ok there is a guy on here(MouhadIb) selling a JDM R limited slip with the ring gear on it. Will this fit in my b16(00si) tranny and what will the final drive be, 4.4 or 4.785? Thanks
Old Oct 6, 2002 | 05:56 PM
sackdz's Avatar
Default Re: Question about R LSD (lube)
I believe you'll need a new countershaft and 1st gear (needle bearings too) as well.
Ratio will be 4.785:1
Old Oct 6, 2002 | 05:59 PM
sneakychaos's Avatar
Default Re: Question about R LSD (sackdz)
:nods:
Old Oct 7, 2002 | 09:09 AM
lube's Avatar
Default Re: Question about R LSD (sneakychaos)
So I will need the JDM 1st gear and countershaft? Is that all? Thanks again
Old Oct 7, 2002 | 09:18 AM
chrisJ's Avatar
New User
depends if its a 98plus ring gear or not. 98 plus = 4.78 but if not then its just a 4.4, either way, u can still use ur ring gear on the lsd and it will drop in. make sure u check the clearances on the bearings/shims when installing tho
Old Oct 7, 2002 | 10:14 AM
lube's Avatar
Default Re: Question about R LSD (chrisJ)
It's a 98 tranny, so it has the 4.785 right?
Old Oct 7, 2002 | 11:03 AM
Hooch'n's Avatar
should work.........
Old Oct 7, 2002 | 11:20 AM
lube's Avatar
Default Re: Question about R LSD (Hooch at 8400-RPM)
What's up with the ?
Old Oct 7, 2002 | 11:26 AM
B2FiNiTY's Avatar
yup.
jceltalentoso
Transmission & Drivetrain
May 13, 2014 09:05 PM
mach3lude
Aug 29, 2011 07:18 AM
hfrex
May 14, 2009 03:20 PM
migs
Dec 3, 2008 03:52 AM
G2ILS
Aug 7, 2005 10:11 PM
