1993 Civic CX - what offset to use??
I'm looking at some 15x8 inch rims, XXR 522. They come with a 0 offeset, how will they fit? Or will they fit with out rubbing.
I am building this car up to track and autocross. They also sell 15x7 with +25 offset.
Which one wont rub and requires little or no modification to the car.
I plan on running 224/45-15 R-S3.
Thanks for you help!
Pretty sure a 8" with a 0 offset will poke out of the fenders like crazh. Your tire size is good especially with a higher offset.
Think your better off going with the 7" with a 205/50 as I think that a 225/45 will bulge on a 7" wheel
Thanks for all your input, if I was wanting to run 15x8. What offset should i look for? I know I might have to roll my fenders. I just dont want to have wheel rub.
Thanks!
Thanks!
I think it depends on three things weather or not you need to roll the fenders:
- negative camber
- tire width
- ride height
Hell, 16x8 +20 & 205/40-16 seem to fit Integras (front fender do look a little rolled):
- negative camber
- tire width
- ride height
I think 15x8 on a Honda is a bit ridiculous, especially for autox/tracking. I know having wider rubber is better, but if you're rocking a set up that doesn't fit/work with the car, it's pretty much useless. Go for form over function. I haven't really seen many trackable Civics with tires over 205. If anyone rocks such a setup, I would love to check it out.
I was thinking of going with the hella flush look on my hatch and was told to run the 15x7 and no more the a 10 on the offset. I am lowered 2.5inchs though.
Rising_Sun_Inc
Acura TSX
Jul 5, 2011 02:23 PM
lonefuzzy79
Jul 27, 2006 02:05 PM
