My key wont unlock any doors on my 96 Coupe EX
I just recently bought the 1996 civic coupe EX. When I got home I realized the keys do not unlock or lock the doors from the outside of the car. The power locks inside the car works fine to unlock/lock doors.
The car doesnt seem to have had an alarm installed, I believe this has to be an issue with the factory keyless? It doesnt have a factory radio so I know the keyless will not work regardless but how can I lock the car if I cannot unlock it?
No, the key goes perfectly in the cylinder and turns both ways, it just doesnt do anything.
Im pretty sure the stock radio isnt behind the center console since the dome light (celing light) doesnt work and thats also a feature connected to factory radio. I know thats a quick fix, but why wont my doors lock/unlock?
Remove the driver's door panel, unplug the 4P connector for the driver's door lock actuator, and then ground the Blu/Wht wire in the 4P connector. Does the passenger door lock?
Contact the seller and see if they have right keys?
Wait, does the key start the car?
1. The cylinder turns so you are mechanically unlocking the pins allowing it to turn; you have the right key.
2. The electric locks should not have any effect on the function of the mechanical locks; if the key turns then the door should unlock.
It sounds like the linkage between the cylinder and the lock is disconnected; it might be for theft prevention or something along those lines.
I agree. The electrical part of the driver's lock actuator that works through the key also must be disabled. That's what I was chasing.
gilheaven
Oct 15, 2012 12:20 PM
GRNcivEX
Oct 3, 2012 09:27 AM
ej8ster96
May 9, 2012 07:13 AM
