94 Civic Ex Cel code #7
Old Oct 31, 2011 | 07:11 PM
96DelSol's Avatar
Default 94 Civic Ex Cel code #7
Alright guys just got a Civic Ex d16z6, just fixed the overheating problems and leaks.
I checked the cel and it says code 7, which is tps.
Problem is the idle would go up and down but cel would only light up after 15 minutes of driving.
I replaced with blox tps and as soon as I start up the car I get a cel (code 7), replaced that one with oem one and same thing.
In other words, I have tried 2 tps and cel keeps coming back.
Im also gonna set it at 0.50 at idle tomorrow morning but I doubt the cel will go away.
Help
Old Oct 31, 2011 | 08:29 PM
Former User's Avatar
Default Re: 94 Civic Ex Cel code #7
Does the Yel/Wht wire in the TPS connector get 5 reference volts from the ECU when using the Grn/Wht wire as ground?
Old Nov 1, 2011 | 04:52 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Above is how to set the TPS, take note of this picture to ensure proper setting of the voltage
Also you said you fixed an overheating/leak problem? Did you bleed the cooling system afterwards?
Old Nov 4, 2011 | 12:59 PM
96DelSol's Avatar
I got 0.06 when I checked.
Also just checked ecu and idk why but someone put in a p06 in the car.
Old Nov 4, 2011 | 01:01 PM
96DelSol's Avatar
Thanks for the link on the tps setting example hondaparts, but im gonna pickup a whole throtle body for it, that way I won't mess with the tps anymore just plug it in.
And yes, car was overheating due to a clogged radiator, i replaced radiator and I bled the system but used water, Just bought the antifreeze, Im gonna drain and refill and bleed and put tb tomorrow, hopefully this gets fixed.
qwertynerd
Honda Civic (2001 - 2005)
Jun 10, 2014 07:43 PM
nicefighter80
Jan 15, 2011 08:53 AM
A92civicxJDMb16a
Oct 13, 2003 02:29 PM
