Changing a Thermostat
Old Oct 31, 2011 | 04:14 PM
motegicivic's Avatar
Default Changing a Thermostat
96 Civic EX
First question, can you get away with changing it without draining the coolant, I know some coolant will spill out if you don't.
Do you need to remove the upper hose or can you get away with leaving it on?
And, do you need to use gasket sealer/silicone to put it back together, or can get away without it?
Old Oct 31, 2011 | 04:23 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Changing a Thermostat
http://www.youtube.com/watch?v=w4660OXzoeo
Old Oct 31, 2011 | 04:27 PM
Former User's Avatar
Originally Posted by motegicivic
96 Civic EX
It is just more messy if you don't drain the coolant.
Not removing the upper hose is fine
Just proper installation of the gasket is adequate
Old Oct 31, 2011 | 04:40 PM
Thanks Ron, I know you should drain, I was going to take the lazy way out.
By the way how much torque on the bolts, or nice hand tight enough?
Old Oct 31, 2011 | 04:42 PM
8.7 lb-ft
lfunk11
Honda Civic (2001 - 2005)
Jan 16, 2012 12:34 AM
CleanHatch
Nov 5, 2005 12:19 AM
spcrxracer
Feb 27, 2005 11:16 AM
specialedition
Jan 11, 2005 05:32 PM
BoostedB20A
Aug 3, 2003 11:18 AM
