Need help with rear disk conversion..pls help!
i have a 94 eg hatch that im trying to put rear disk brakes on...
i have a 92 eg hatch shell that im trying to take off the disk brakes from and put them on my 94......
how do i do this please help..step by step.
thank you.
thank you.
Step 1-Pull off everything off of the old car.
Step 2-Pull off everything off of the new car
Step 3-Install everything from old car on new car.
Or you could check the FAQs
http://civic-eg.com/viewtopic.php?t=4129
or Google and get a search result like this one.
http://www.google.com/search?hl=en&l...nversion+civic
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-rear-disc-brake-conversion-how-w-parts-pictures-56k-haha-641639/
https://honda-tech.com/forums/showthread.php?t=641639
Put car in gear or bricks if cant
Get under an take off any bolts that holds the ebrake cable(10mm)
Get inside the car take apart the ebrake(12mm) and feed the lines through
Take the brake line off
Take trailing arms off, camber, lca(14,17) if it's too rusted, just give up
Or be like me and brake the bolt that is welded to the chassis, take out the grinder and cut the bolt and cut a hole in the chassis to get to the bolt and weld a new one lol had to do that to a lot of bolts, it's a flood title lol
Good luck
Good luck
step number ONE
https://www.google.com/search?aq=f&g...isk+conversion
Seriously, if you're not willing to do the simple job of googling/searching out many of the already thorough threads there are on the subject you're not up to the simple job of a rear disc swap.
this bolt is supposed to adjust and slide to adjust the toe/caster... i just did mine and broke many bolts and had to give up one night and continue the next and got new lower control arms because i didint grab the ones from the donor car and the bushings tore and bolts got rusting inside the bushing sleeves.
i just drilled a hole out with a step bit on the bottom and put the stock caster nut back in the slot where it sat. i found another 14mm bolt from my random leftovers from over the years to fit. i guess if u snapped that bolt u would have issues but those were the only two that came off thank god.
