Harmonic balancer bolt help
Old Oct 30, 2011 | 03:18 PM
1995hondaEJ's Avatar
Default Harmonic balancer bolt help
I got a d16z6
And yesterday the harmonic balancer fell off
Got the woodruff key from Honda already
But is there anywhere else I can get the bolt
Cuz I forgot to get it and I need to drive the car till
I can go to Honda Tuesday
Already checked autozone etc
Is there any bolt size I can use or does it have to be the specific
One for that car
Thanks
Old Oct 30, 2011 | 03:24 PM
98civdx's Avatar
Master Detailer
Default Re: Harmonic balancer bolt help
I am 99.999995% sure that bolt is unique to the crank.
And you cant just go throwing anything in there and risk screwing up the threads of the crank.
Old Oct 30, 2011 | 03:55 PM
sde780's Avatar
You most likely won't find another bolt that'll fit and even it does, I wouldn't risk it.
Old Oct 30, 2011 | 05:26 PM
Hidenplanvew's Avatar
your going to have to wait for honda
Old Oct 31, 2011 | 12:43 AM
Cool thanks
I know they're hard to take off
But are they easier to put on
What will I need
Old Oct 31, 2011 | 03:26 AM
BryanM.'s Avatar
Resident Gearhead
If you have access to air tools, an impact gun is all you need.
Without air tools, a hex pulley tool will come in handy.
If you can't get one, you'll have to figure out a way to keep the crank
from turning as you torque the pulley bolt.
Old Oct 31, 2011 | 06:33 AM
thenext's Avatar
20% cooler
Take out the starter and get a 3 ft prybar on your flywheel to stop it from moving.
Old Oct 31, 2011 | 08:34 AM
Dam sounds like a b&&& to do
O well bout to go buy the bolt right now
I would take it to a mechanic but I spent
All my money on beer fml
Old Oct 31, 2011 | 08:47 AM
Dc4LsTeG's Avatar
EK9
Put a chain wrench on the crank pulley put the chain wrench against the motor mount and tighten crank pulley bolt
Old Oct 31, 2011 | 09:02 AM
thenext's Avatar
20% cooler
Old Oct 31, 2011 | 01:00 PM
d151/2's Avatar
pull out your number one sparkplug and stuff about 6 feet of nylon rope down into your cylinder that will keep the motor from spinning. umm just make sure you leave some rope hanging out. have used that method on multiple occasions always works.
Old Oct 31, 2011 | 03:16 PM
Homie came thru with impact gun
Now I just got a squeaky belt when I start it
For like 3 seconds then goes away
Thanks for the help
Old Oct 31, 2011 | 03:18 PM
98civdx's Avatar
Master Detailer
Tighten it more.
Happened to me with my alt belt, wedged a pry bar between the block and it, pry back.
It was a new belt, though.
Old Oct 31, 2011 | 03:23 PM
No oilpan isn't leakin lol
Just postin pics if anybody has same problem
Old Apr 19, 2012 | 06:35 PM
civicboi12's Avatar
Same thing happened to me , what size bolt is it i cant find it anywhere?
Old Apr 20, 2012 | 04:23 AM
BryanM.'s Avatar
Resident Gearhead
Get it from Honda, #16 here --> http://www.hondaautomotiveparts.com/...N+-+CRANKSHAFT
^^ That bolt will work for D & B series.
I highly doubt you'll find this bolt at Autozone or any regular auto part store.
And as stated earlier in the thread, good luck finding a bolt at a hardware store
that will work.
whitehf
12
Oct 13, 2011 08:12 AM
DaKINE-Ek
Aug 14, 2006 05:22 PM
BB6racer
Aug 10, 2005 11:50 AM
JDMKid71
Mar 20, 2005 11:46 AM
legendboy
Nov 22, 2002 10:42 AM
