Crank Pulley Bolt
Crank Pulley Bolt
I posted last night about my pulley falling off... i lost the bolt and set key. Do i have to go to Honda and get a new boly and Key or can i pick the right size bolt up from the local harware store? and where woudl i get the set key then? Thank for the help in advance.
TJ
TJ
Re: Crank Pulley Bolt (JDMKid71)
When this happened to me I found the original bolt and ground a new key from an allen wrench. You may want to look for the bolt if you know roughly where it fell off. I don't think there will be a similar fastener at any local hardware store...
Re: Crank Pulley Bolt (phasewest)
you must get the bolt from honda its a special bolt and has to be torqued a special way youll see on the instructions it comes with i forgot how much they cost not too much though. and get the key while your at honda too. you wont find the correct threaded bolt at a hardware store so dont bother.
