GSR question need answer quick
I have a full type r conversion GSR car but still have the stock gsr motor in it I have a set of type r pistons and rods I was told they will fit right in my car no problems cause the rods are very similar to gsr well I bent 2 rods in it and now its time they go in but I wanted to make sure there wont be a problem putting them in I wanna make sure clearance is good an make sure that they will fit on the crank properly ur help will be much appreciated thanks
if you want more torque use a ls crank and ls rods, they have more stroke (more torque) and use them with you Type R pistons. Pick up some arp rod bolts and you wont have any problem reving to gsr/typr rev limit.
What will compression be after I put em in? Sorry for pickin all yu guys brains lol ive built mad singles junew wi stuff such as this in b series just traded my vitara build for this
slayersluck
Jun 16, 2005 05:03 AM
