HELP! My Integra Wont Start!
Old Oct 28, 2011 | 06:50 PM
ayang89's Avatar
Default HELP! My Integra Wont Start!
I have a 93 Integra DA that has a JDM b16A motor in it. It doesnt want to start anymore. I took it to the shop and they said it was the starter. Replaced the starter and it still doesnt start. Car doesn't start unless you push start it. What could it be? HELP PLEASE!!!
Old Oct 28, 2011 | 08:46 PM
fcm's Avatar
fcm
Old Fart
Default Re: HELP! My Integra Wont Start!
So the car runs if you bump start it, [push start]. if you have a 12V test light and a jumper you can diagnose the problem pretty simply...
https://honda-tech.com/forums/showth...&highlight=fcm
94
Old Oct 28, 2011 | 08:55 PM
komat's Avatar
does it crank over? if it doesnt , its probably you clutch safely switch not being engage. check if your clutch pedal still has the rubber stopper
Old Oct 28, 2011 | 09:04 PM
ayang89's Avatar
Nope. it doesnt even turn over. No crank no nothing.
Old Oct 28, 2011 | 10:34 PM
DirtyDA9's Avatar
Flywheel. If you replaced the starter then it's the flywheel
Old Oct 28, 2011 | 10:40 PM
ayang89's Avatar
What?!!! That would sukk assss. All my light n everything works. Just wont crank. Just a click then thats it.
Old Oct 28, 2011 | 10:50 PM
komat's Avatar
did you check the clutch switch and the clutch pedal for the rubber to that engages the clutch switch
Old Oct 28, 2011 | 10:51 PM
ayang89's Avatar
No idea what i would be looking for. Lol
Old Oct 28, 2011 | 10:54 PM
komat's Avatar
you see the clutch switch(has a yellow connector) on the picture. make sure that rubber stopper is on the pedal. they tend to rot out and fall out. if its not there, you can either buy a new one or unbolt the switch and tape the trigger down til you get a new one
Old Oct 28, 2011 | 10:58 PM
ayang89's Avatar
Ill have to check it out in the morning
Old Oct 29, 2011 | 11:15 AM
fcm's Avatar
fcm
Old Fart
Do the test I linked you to, it will tell you if the problem is the starter or wiring before the starter, [ign. switch, CIS, starter relay or wiring between them].
All the above are common problems on older Honda/Acura, the liked test is easy to do and it will narrow down where the problem is. 94
Old Oct 29, 2011 | 12:02 PM
DirtyDA9's Avatar
^^^ Agreed.
Old Oct 29, 2011 | 12:43 PM
ayang89's Avatar
Did both tests. Light turns on for both.
Old Oct 29, 2011 | 02:43 PM
komat's Avatar
im putting my money its the clutch pedal missing hte rubber stopper to engage the clutch switch.....
Old Oct 29, 2011 | 02:54 PM
ayang89's Avatar
Still couldnt find what your talking about even with the picture. Do i have to take off the cluster to see it?
Old Oct 29, 2011 | 02:57 PM
komat's Avatar
no....
you lay on the floor and look up with a flashlight. just follow the clutch pedal up til you find a switch
Old Oct 29, 2011 | 03:00 PM
komat's Avatar
heres a pic of what the switch looks like
http://www.stockwiseauto.com/product...ource/googleps
make sure the pedal has hte rubber stopper to engage it
Old Oct 29, 2011 | 05:50 PM
DirtyDA9's Avatar
Just follow the clutch pedal up.
Old Oct 29, 2011 | 08:27 PM
fcm's Avatar
fcm
Old Fart
What do you mean, that makes no sence at all.
The test light "test", [testing "low" current starter circuit] is the only one that a light "turns on".
And if it does, then it is unlikely there is anything wrong with the ign. switch, CIS, starter relay or wiring.
The other test is a bypass jump, it tests the "high" current starter circuit along with the starter motor and starter motor solenoid, there is no light to come on, the engine will crank or it will not. 94
Old Oct 29, 2011 | 09:09 PM
ayang89's Avatar
Ok, so how do you bypass it again? Lol,sorry. Im a noob to this stuff.
Old Oct 29, 2011 | 10:10 PM
komat's Avatar
if he cant or havnt even check to see if its the clutch neutral switch yet. i doubt hes going to know how to do the test light check
Old Oct 29, 2011 | 10:23 PM
LordAphotic's Avatar
make sure the ground cables are in place. if they arent the started will not crank
Old Oct 29, 2011 | 10:29 PM
ayang89's Avatar
I checked the ground wire where it connects to the bottom right of the valve cover to tue front engine bay. Thats the only ground wire that i know of.
Old Oct 30, 2011 | 11:23 AM
fcm's Avatar
fcm
Old Fart
The link I posted tells/shows you how to do a bypass jump, there are pictures to make it as easy to understand as possible.
The same goes for the starter circuit test, explained with pictures.
You say it lights up your test light, so start circuit must be good
I do not know how to explain it any easier way.
There is a grand from the chassis to the engine, [transaxle] you will need to remove the batt. fallow the batt. neg.(-) cable to the chassis ground point and then from the chassis ground point to the engine.
Make sure both those two ground points are good, but before you do that, try the bypass jump, if the bypass jump does not work then check, [redo] the grounds and try the bypass jump again, if still not working the starter motor or starter solenoid is bad.
https://honda-tech.com/forums/showth...&highlight=fcm 94
egtony
Jun 11, 2009 10:48 AM
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
DC4 Rasta
Aug 30, 2007 10:38 AM
OfTheSun
Apr 6, 2006 10:29 AM
del_parker
Oct 25, 2003 08:06 AM
